RSR Struts, Are these the only front coil-over opt? |
johnmhudson111 |
Jan 6 2006, 01:25 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
Are the RSR type front strut the only option there is to convert the front suspension to coil-overs?
Mueller |
Jan 6 2006, 01:32 PM
nope, you can convert the regular /4 stock struts to coilovers as well........
johnmhudson111 |
Jan 6 2006, 01:36 PM
I would assume the same is true for 911 struts.....cool thanks! |
Mueller |
Jan 6 2006, 01:40 PM
if you have a good imagination, picture doing this mod to the front....
rear shock adjustable coil over conversion (crude method) it's ugly, but it works.... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Scott |
Jan 6 2006, 03:58 PM
Member Group: Members Posts: 208 Joined: 13-January 03 From: Redwood City, CA Member No.: 138 |
Smart Racing makes a fully threaded strut with a adjustable height spindle. If your gouing to go for it, may as well go all the way.
KenH |
Jan 6 2006, 04:03 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
"Spring Rate is Spring Rate"... why take away the Torsion Bars and replace with springs??
Ken |
TimT |
Jan 6 2006, 04:14 PM
Becuase if your hunting around trying to find which spring rate works best on your car, its quite easy to swap coil over springs. Torsion bars arent that easy to quickly swap. Also when you do a spring change with coilovers you typically dont lose and alignment settings. On a street car its probably overkill, but on a racecar its convenient.We carry a slection of springs in the trailer |
Aaron Cox |
Jan 6 2006, 04:27 PM
lets see... 3 torsion bar sizes... (4 counting stock...) or 100's of spring rates.... you know you can get coils in 5-10lb rates? hmmmm.... fine tuning is the key..... |
Lo-Fi Version | Time is now: 4th May 2024 - 08:58 AM |
