Clutch cable, came loose? |
redshift |
Jan 6 2006, 09:28 PM
I hope I haven't destroyed my synchros double clutching for a mile... freaking shitty mechanic.
M |
TROJANMAN |
Jan 6 2006, 09:58 PM
Looks nice in pictures......... Group: Members Posts: 5,264 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
uhhhh,,,,,,isn't this garage fodder? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Lou W |
Jan 7 2006, 12:00 AM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Have one of our mechanics look at it over in the garage. (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Pinepig |
Jan 7 2006, 12:26 AM
Newbie Group: Members Posts: 28 Joined: 1-January 06 From: Sacramento, CA Member No.: 5,350 |
I used to have one that would eat clutch cables ( busted tube coming out of the tunnel ) When I had to stop I'd just slip it out of gear, and turn the car off. Time to go, put it in third and turn the key.
I put a Neal hydro clutch padal and slave in it and never had a problem again, I loved the clutch in that 914. |
rick 918-S |
Jan 7 2006, 01:18 AM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) where'd you get that? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
redshift |
Jan 7 2006, 04:35 PM
Oh my gawd... it's in the garage..
I changed cables over a week ago.. everything looks fine, except the nut on the adjustment end won't stay... it's stripped... I adjust it fine, push in... and back to square one.. SUCK ME NUT CRAP M |
Jan 7 2006, 04:48 PM
so you have a loose nut, a stripped nut, one nut that wont stay where you put it, or are you having problems with both your nuts?
I would say get some new nuts, nylock and go from there. Rich |
bd1308 |
Jan 7 2006, 04:49 PM
its a wierd nut....smaller than the generic 10mm nut. i think its actually the same wierd thread pitch one thats used on the rocker studs.
b |
redshift |
Jan 7 2006, 05:00 PM
I can't be on both ends at once.. I heard a quiet sound... I think it may be the tube.
Can you repair a tube by jambing something in the tunnel to hold it in place so you can drive to a repair thingy? M |
Allan |
Jan 7 2006, 05:02 PM
Aren't you double nutting it?
bd1308 |
Jan 7 2006, 05:03 PM
chopsticks work great...
four of them with twist ties all over it should work put it in angles like this /\ \/ but the middle section should touch the clutch tube. bubble gum might work either. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) b |
Jan 7 2006, 05:12 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Did you use one of the standard 13mm wrench-size nuts? Betcha did--sounds like what happened to me when I did that. You neet to use an M7 nut, 11mm wrench size. Two of them, tightened against each other, and that sucka won't go anywhere! I tired Nyloc, but it didn't hold well enough. --DD |
redshift |
Jan 7 2006, 05:55 PM
Gotta BE DA TUBE
Dark:45 out right now.. can you glue the tube in temporarily? M |
bd1308 |
Jan 7 2006, 05:58 PM
if you need to limp it to a shop, just keep it in second gear
b |
redshift |
Jan 7 2006, 06:01 PM
hahahah RIGHT
M |
bd1308 |
Jan 7 2006, 06:06 PM
Pinepig |
Jan 7 2006, 08:16 PM
I believe I ordered it fmon CB Performance back in the day, it was a clutch pedal assymbly for a sandrail. Looked just like this one about halfway down the page. Click me |
Allan |
Jan 7 2006, 10:32 PM
Yer gonna get yelled at for yer avatar.
redshift |
Jan 7 2006, 10:57 PM
redshift |
Jan 7 2006, 11:02 PM
So, can I epoxy this thing in?
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I need to fix it to get it to the fixing place. M |
Lo-Fi Version | Time is now: 8th May 2024 - 03:05 AM |
