OT, Toyota pwr antenna, up and down function? |
smooth_eddy |
Jan 8 2006, 03:59 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
My 95 Toyota trucks antenna is not working too well. The motor works fine that drives the antenna. Problem is the antenna works only with a manual push or pull most of the time. I removed it and cleaned the plastic extender/retractor gear and put it back together, but same results. Any ideas? I know this is not 914 content, but where else will I get help (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Thanks, Eddy
jet1 |
Jan 8 2006, 04:22 PM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
I replaced the antenna on my dad's 4runner and had trouble getting the gear teeth to line up the right way with the plastic retractor line that is inside the antenna. maybe the antenna is slightly twisted? also, you may want to try wd-40 on the antenna while it is in the extended position to clean any crap off that might be causing it to stick.
smooth_eddy |
Jan 8 2006, 04:56 PM
Yes, I did use WD40 to clean the whole thing up with. And yes, I did play with alignment of the gears. The gears on the antenna seem to be okay, but there is some grinding going on. The antenna mechanism slides up and down easy. Still confused. Eddy
Lo-Fi Version | Time is now: 15th May 2024 - 01:01 PM |
