boxster engine, can a boxster engine be placed into a 91 |
armrad |
Jan 9 2006, 10:28 AM
Newbie Group: Members Posts: 2 Joined: 9-January 06 From: Newfields, NH Member No.: 5,393 |
Thinking about doing a conversion of my 74 1.8 type 4 motor. Would rather stay Porsche than a Subaru conversion. Has anyone used a boxster 2.5L water box? Will it fit without much rearranging? How about the trany, will a boxster engine mate to a side shifter or will the trany off a boxster mate to the rear wheel drive of a 914?
lagunero |
Jan 9 2006, 10:53 AM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
It seems that the Boxster motor will not fit without major mods (rear suspension).
anthony |
Jan 9 2006, 10:56 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Brad's friend Jason (what ever happened to him?) was doing a Boxster conversion and to make it fit they were adapting a Boxster rear suspension to the 914.
ConeDodger |
Jan 9 2006, 11:16 AM
Apex killer! Group: Members Posts: 23,581 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
There is a guy local here in Sacramento putting a 3.X motor from a late model car complete with its stock EFI. The motor is similar in dimension to the Boxster 2.5. He had his suspension tube framed and externally valved shocks done by a race car shop out by Sears Point. I am not sure what that cost but Mikes pockets are deep enough I suppose...
Rob |
neo914-6 |
Jan 9 2006, 11:45 AM
This was just being discuss, look down the page... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
SilverBullet |
Jan 9 2006, 01:33 PM
Member Group: Members Posts: 71 Joined: 30-December 02 From: San Jose, Ca. Member No.: 53 |
Hi!
Here I am (Jason) Neo thought that I should chime in. The project is coming along. I don't spend time on the board, because I'd rather be in the garage cutting and welding. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Simply put you will have to cut the suspension tabs out of the engine compartment for any of the Boxster or 996 motors to fit. There is not enough room. To further discourage you, the motor will need one of the following forms of engine management: Reflash the ECU (~$1500 min) because the ECU is programmed to see many components in the chassis (ABS, multiple ECUs, instrument cluster...). Or you can run a fully tuneable stand alone engine management system. (~$700 on Ebay.) Megasquirt (cheaper) can't be used unless you are super programming savvy and have lots of time on your hands to iron-out issues. It hasn't been done and there is no support for it yet. You would need to control the Coil on plug, and Variocam, and perhaps fly-by-wire. Or a completely different approach might be to pull the EFI and run carbs, but I've not looked into that. I will be running a programmable stand alone engine management sys, and using the factory rear suspension from a boxster, along with the factory trani. For those components expect to spend over $3k not including the motor. You might also consider this approach, but keep in mind the axles will need to be custom: http://cgi.ebay.com/ebaymotors/Porsche-996...1QQcmdZViewItem I probably won't be back on the board for another month or so. Good luck to you if you decide to pursue. It'd be nice to compare notes as your project comes along. |
IronHillRestorations |
Jan 9 2006, 07:22 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Don't want to rain on your parade, but as cheap as Boxsters are you'd be better off finding a good used NEW 914-6, instead of trying to make a 914 into a 986! Have a good air cooled one, and enjoy the creature comforts and 914 similarities of the NEW 914-6!
It be alot easier, faster, and a whole lot less Star Trek..... |
Lo-Fi Version | Time is now: 11th May 2024 - 07:33 PM |
