Teeners and Cold Weather, I am beginning to sense a pattern.... |
Flat VW |
Jan 9 2006, 12:11 PM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
Hello to everyone, (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif)
Well merely conjecture, but the few times I have encountered cold weather, I have had odd operation out of my car, in some way or other....... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) I was just in Marble Canyon, Arizona for some fishing and it was cold there, got down to about twenty degrees F. I went out in the morning to pop the front trunk to retrive Laurie's "cold weather gear" and at first it would not function. I had just recently adjusted it and it is "set up" just right. I found that if I pulled and held the cable for a moment, it would function fine. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) I also had my speedometer make a "really cool grinding noise" during our twenty minute drive down to the Colorado River in the morning, but, once it was time to leave and nearly fourty degrees warmer, it functioned fine. Well my question is what are some common "cold weather maladies" some of you must endure with your teener? I do realize many are put away for winter. What is the coldest weather you have ever operated your teener in? John (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) P.S. If one had no impeller fan running on a MOVING type four car, and it were cold enough, could it ever be cold enough to operate the car without damaging the engine? How cold? |
Joe Ricard |
Jan 9 2006, 12:15 PM
Answering your last question 1st NO
Other things that happen to my car when it gets cold: Gear selection is stiff till the tranny warms up the ignition key in stiff till the car warms up (need to clean it) Colder than a witches tit till I drive it down the road and build heat in the exhaust. |
KaptKaos |
Jan 9 2006, 12:53 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
More importantly, what kind of fishing were you doing?
bd1308 |
Jan 9 2006, 12:58 PM
I've been in twenty degree weather with my 914. My 914 is a daily driver....
With L-jet it has *NEVER* given me one issue. with the carbs, i always had to fiddle with it. John, your IDFs dont have chokes....it was like Charles (LN) when he started his 911T, ya gotta gas it until the carbs stop spitting. Plus your IDFs werent tuned to KY elevation anyway. b |
toecutter |
Jan 9 2006, 01:03 PM
Kid Close Enough Group: Members Posts: 37 Joined: 6-March 05 From: Sherman, Texas Member No.: 3,723 |
After the motor finally warms up it runs the best when it's butt ass cold outside. Of course so do I as opposed to when it's 104 here in Texas. My car loves 30 or 40 degrees. Runs like a scalded dog!
GeorgeRud |
Jan 9 2006, 01:10 PM
I had a 914 2.0 as my only driver back in 1974 (when we were both young), and here in Illinois I had it out in below zero weather many times. Once everything gets warmed up, it worked well and the heat exchangers kept us nice and warm. Till then, nothing really wanted to work well. I seem to remember getting a dipstick heater to keep the oil flowing on the real bad mornings.
Don't worry about the cold weather though, it was driving it in the snow on regular tires that was really a challange. Central Illinois had lots of highly crowned farm roads with deep ditches to catch you. Thank God for winter cars and Blizzaks! |
Flat VW |
Jan 9 2006, 01:22 PM
Trout fishing, upriver from Lee's Ferry. It was slow, few fish, all small. The word is that Lake Powell above the dam (Glen Canyon) got so low this year that water was drawn from a warmer thermocline (sp?) this year resulting in high Colorado River water temps, 60 degrees F. as opposed to a usual 47 degrees F. . The annual spawn had not started yet and is normally in full swing at this time. I love to take out-of-town guests there as it is such a beautiful place that if one ends up with good fishing it is only a bonus. John P.S. We took a guided trip up river this time..... |
mudfoot76 |
Jan 9 2006, 01:25 PM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
No IDF carbs have chokes -- and you've likely figured this out already, but when it is cold, once you get it started, let it idle for a few minutes. The last DE I went to it was in the mid 20s on the first day. It was a beeotch to get the car started, but once it got a little warm, it stopped coughing and spitting and ran really strong.... |
Flat VW |
Jan 9 2006, 01:28 PM
George, your comment reminded me of the "farm roads" I frequented in Michigan as a kid about the same time you had that teener. Some were so crowned they were nearly a hazard dry! John P.S. High-center a teener? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
KaptKaos |
Jan 9 2006, 01:33 PM
Trout do not like it that warm, that's for sure. I have read about Lee's Ferry, but do not know much about what hatches there and when? Were there any hatches at this time of year or were you nymphing? I have read stories of football sized trout being pulled out of there. I need to get out there sometime. |
Flat VW |
Jan 9 2006, 01:36 PM
I think I finally have the tune right on these carbs. It started right up, the Pertronix makes all the difference (thx AA). The cold starting issues I have had were all "points based", as I look back, I am nearly certain. That is what Brad Mayeur had suggested from the first, P-O-I-N-T-S. John (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Aaron Cox |
Jan 9 2006, 01:37 PM
uh my IDF's have chokes |
Aaron Cox |
Jan 9 2006, 01:42 PM
dont make me quote myself again.... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Attached thumbnail(s) |
Dr. Roger |
Jan 9 2006, 01:43 PM
When my sister lived in Evergreen Colorado she couldn't set her E brake over night because the rear drums would be seized the next morning. Engine block warmers were mandatory even in the garage. Sticking the door key in the lock was impossible unless you had some sort of method of defrosting the lock mechanism... LOL Roger (IMG:http://www.914world.com/bbs2/uploads/post-37-1136828754.jpg) |
mudfoot76 |
Jan 9 2006, 01:45 PM
Really? Mind don't.....AFAIK, they weren't designed with them...but what do I know? Just enough to be dangerous (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Aaron Cox |
Jan 9 2006, 01:47 PM
most ive seen have block off plates.... mind you these weber IDF's were bought new 3 years ago.... |
mudfoot76 |
Jan 9 2006, 01:58 PM
Very interesting...a PO installed the 44s currently on my car. The choke setup on your car - is it something you control or are they automatic? I'm just curious... This post has been edited by mudfoot76: Jan 9 2006, 01:59 PM |
Elliot_Cannon |
Jan 9 2006, 02:00 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
I have no idea how my car runs in cold weather because when it gets below 50 degrees I lose consciousness.
Elliot |
Flat VW |
Jan 9 2006, 02:01 PM
We were using roe imitations (glo bugs) and "San Juan worms", even with the spawn not at speed yet the roe imitations were best. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) There was a Midge hatch underway at the time but we were "drift fishing" for this trip. (IMG:http://www.914world.com/bbs2/html/emoticons/ph34r.gif) John P.S. I have waded at Paria Creek just downriver from the Ferry many times, when the fish are happening it is some of the best fishing I have ever seen. The release levels can vary wildly though, particularly in the summer, and caution is needed when fishing there. |
Aaron Cox |
Jan 9 2006, 02:43 PM
they are cable operated... but not hooked up. weber 44's..... |
Lo-Fi Version | Time is now: 11th May 2024 - 01:43 AM |
