stuff for the car, when I get it back |
DanT |
Jan 9 2006, 05:45 PM
So I got bored waiting for my car to come back from the painter.
Decided to do a little quick fab work. Made some backing plates for my roll bar and petty bar, I bought it used and the backing plates had long since been misplaced. Steve H. this is the rollbar out of your car when Mike owned it (cage installed upon RB removal). Since I was painting the plates decided to tidy up the roll bar and petty bar with a little fast dry gloss black paint. Most of it will be covered by roll bar padding, but what the hay! While I was at it decided to make some cover plates for the foglight openings, since they are removed now anyway. Not bad for a couple hours work (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Now for a car to install this stuff on! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Pic of roll bar Attached image(s) |
DanT |
Jan 9 2006, 05:46 PM
Backing plates (steel, of course)
DanT |
Jan 9 2006, 05:47 PM
And foglight area cover (in aluminum) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Jeroen |
Jan 9 2006, 06:52 PM
don't you need to weld some nuts to the backingplates?
DanT |
Jan 9 2006, 07:17 PM
Nope,
bolt directly through the floor pan. Through and through. Bolt, washer, backing plate, floor pan, foot plate of roll bar or petty bar, washer, nyloc nut. done deal (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
DanT |
Jan 9 2006, 10:09 PM
Here's some other stuff I have sitting around waiting for a car to put it on.
Attached thumbnail(s) |
DanT |
Jan 9 2006, 10:11 PM
and some self polished wheels that will have Yoko A032Rs mounted soon.
DanT |
Jan 9 2006, 10:17 PM
And Bilstein sports with 180# springs
Also have M calipers and billet hubs to retain 4 bolt pattern. Koni Sport adjustables, 21 mm torsion bars, rack spacer (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) For the front end. Attached image(s) |
Trekkor |
Jan 9 2006, 11:22 PM
Somebody's getting excited (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif)
Nice parts. I'm getting excited, too. I enrolled in the ground school on Feb 11th today. Yay! KT |
DanT |
Jan 9 2006, 11:32 PM
Great,
I may go and see what John Seidell is up to. See what the new program will look like. That way I know what my new students are exposed to at the ground school. I usually go at least once every couple of years just for that. Yes I am getting excited. Talked to my painter today and he is planning on putting on the paint by this weekend. May have the car back in the next 2 weeks....all orange. Yippeeeee! (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) If he sticks to his program I should have plenty of time to get the thing back together by Sears. How is your repaint going. Full or partial repaint? (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Trekkor |
Jan 9 2006, 11:40 PM
Just talked to Brandon tonight.
I also will be filling the sidemarker and antenna holes. Window squirters are a maybe. Full exterior repaint in light ivory. Randal has offerd his smooth targa top which I will accept for painting. I'm trying to decide if I should section and pull the rear fenders for bigger skins. I hope to remove the bumpers, lenses, chrome, door handles and trims this weekend. KT |
Aaron Cox |
Jan 9 2006, 11:43 PM
awesome. no side marker holes...no antennae holes... and pulled fenders... (sounds familiar) now paint it black....plz |
Trekkor |
Jan 9 2006, 11:45 PM
I will be skipping the first TT with GGR at Sears.
I have other plans that weekend both mornings. I will likely come out and look around on Saturday afternoon. ( Begging for rides ) (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Between Trackmasters, GGR, and SVR there is more track time available than anybody can handle. And then there's my a/x season... (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) KT |
DanT |
Jan 9 2006, 11:51 PM
Before I took my car to the painter I disassembled just about everything other than the front and rear windows. All other chrome, aluminum and rubber trim and gaskets removed.
Smoothed top in white will look very nice (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) I had side markers, squirters, old aftermarket mirrors, bottom B pillar chrome trim, antennae, and rear reflector holes welded over and smoothed. Disassembly doesn't take too long. Took me probably about 6 hours, start to finish. Even took off door panels so he could wrap new paint around so no old stuff would show. I think you will be very happy with the smooth look. It will be nice that both of us are starting the new season with new paint jobs. Don't follow that 911 too close before you pass them....might nik up that new paint! (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Oh well they are race cars, right??? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Trekkor |
Jan 10 2006, 12:06 AM
Mines a repaint of original color so the jambs and trunks won't matter.
I have 2 other targa tops, so I can switch around. You've seen Gary Dorighi's rear flare treatment, right? Pretty cool, I think. Extreme fender pull. Aaron, I had a black 914 before. The yellow showed through in the trunks, inner rockers and jambs. It bummed me out. KT Attached image(s) |
DanT |
Jan 10 2006, 12:18 AM
Gary's car was done years ago, when everyone was doing GT flares. His was one of the first I ever saw with that treatment. It was done by a former GGR member that has since moved on to building award winning hotrods.
His name escapes me right now, but he also painted , Ted and Kevin Voigt's 914-6 2.8L twin plug years ago when it belonged to Tom Van Overbeek (Johannes's (Flying Lizard) dad). He has also painted several 911s that are still time trialed. He does awesome body and paint work! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Trekkor |
Jan 10 2006, 12:26 AM
Gary's car.
Not the greatest shot of the flare. KT Attached image(s) |
DanT |
Jan 10 2006, 12:29 AM
They are very subtle unless you know what you are looking for.
I like them better than GT flares (sorry guys, just my personal opinion) Even the fronts are flared but you have to look closely since the contours follow the original lines so well. |
DanT |
Jan 10 2006, 12:35 AM
I knew it was come to me...(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
I believe Gary's car was done by Bob Cross. At the time he used the business name of CrossCraft. He had a small shop in his back yard. Used a rotisserie and all. He was very thorough in his paint and body process. |
DanT |
Jan 10 2006, 12:39 AM
Cars done by Bob Cross many years ago still TTing with GGR.
Ted and Kevin Voigt Attached image(s) |
Lo-Fi Version | Time is now: 9th May 2024 - 08:39 PM |
