Plug gaps with MSD ignition.. |
DougC |
Jan 10 2006, 03:07 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
Hey guys I was wondering if I set my plug gaps correctly when I installed them in my 2.7L six. I think I gapped them .050" but I was reading somewhere that the range I could use is .050" to .060" . I also think I read somewhere that most people running MSD gap theirs to .040" which is a significant differnce it seems. So how would I benifit one way or another if I was to change the gap? Using stock coil and distributor, 6AL box.
Doug C |
Aaron Cox |
Jan 10 2006, 05:40 PM
i run a .040 with colder plugs....
with mallory coil.... |
J P Stein |
Jan 10 2006, 05:45 PM
With a stock coil and more than stock (.028) gap, you risk running out of spark at high rpms. The stock CIS dizzy doesn't have a good advance curve for carbs. Just my .02 of course. |
Mike D. |
Jan 10 2006, 06:45 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I have a 2.0E engine with a 6al, msd blaster coil and a Bosch E dist. My gap is set at .045. I first set them at .050 but it just looked sooo wide. My engine runs a little rich but you would never know by looking at the plugs. That MSD really burns the gas up and keeps the plugs clean.
SLITS |
Jan 10 2006, 08:03 PM
Hotter spark = bigger gap = better flame front (bigger match to lite the mixture).
0.050 should be safe enough (I coulda said 0.048 ya know) |
joea9146 |
Jan 10 2006, 09:34 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
I run 40 with MSD and a Blaster Coil
john rogers |
Jan 10 2006, 10:22 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
With my MSD 6 box, blaster coil and 9mm wires I use .050 with 100 octane unleaded. If I am going to Mexico or an airport circuit where I will be using 100 low lead or 110 leaded I use .055 for a slightly hotter spark along with 2 degrees more advance.
Lo-Fi Version | Time is now: 11th May 2024 - 08:24 PM |
