> Bottom screws on rocker panels, They're only prolonging the agony!
rjames
post Jan 10 2006, 06:42 PM
I'm made of metal
Trying to get them off, but none of them are budging. Vice grips and DW40 not helping, just chewing the heads up. Can I drill these out without ruining the 'screw recepticals?' (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) (sorry, I'm tired...) Although I'm assuming that the reason I can't get them to move is because they're rusted in there. Flat-head screws suck, btw.
When I do get these out, and assuming I have an outer long that only needs minor rust repairs, how do I go about refastening the under side of the rocker panels?
Thanks!
~Robert
Allan
post Jan 10 2006, 06:46 PM
Teenerless Weenie
I would soak them down with some pb blaster and let the sit overnight.
Bertus
post Jan 10 2006, 06:51 PM
I had to result in using a screw extractor. Had 1 on each side break during removal though. Hopefully nothing too bad lurking under there! (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Lou W
post Jan 10 2006, 06:52 PM
Region Association: Spain
I had the same problem with mine, I sprayed them with M1 All Purpose Lubricant once a day for three days, then used vice grips. If they break off, you'll have to drill and tap new threads.
tat2dphreak
post Jan 10 2006, 06:53 PM
stoya, stoya, stoya
dremel is what one on each side took... I hated to do it, but it had to be...
Dave_Darling
post Jan 10 2006, 06:54 PM
914 Idiot
WD-40 is not a penetrating oil. Get yourself some PB Blaster or Aero Kroyl. Spray the screw, then thump it with a hammer a couple'a times. No, not hard enough to move the sheetmetal around, but enough that the screw knows it's been hit!
Come back the next day, repeat.
Come back the following day, repeat.
If that sucker doesn't move the fourth day (USE THE RIGHT SIZE SCREWDRIVER!!!), hit it with a torch!
--DD
Lou W
post Jan 10 2006, 06:56 PM
WD-40 smells gud. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
bmcwilli
post Jan 11 2006, 07:22 PM
The active ingredient in PB Plaster is iodine. It's got extremely high capillary action.
If'n ya don't need the aerosol , save some bucks and use pure iodine.
I like PB Blaster, but if I don't need to spray it, I use iodine.
Hammy
post Jan 11 2006, 07:45 PM
mr. Wonderful
I got impatient and resorted to drilling mine out... Luckily the new screws fit in just fine.
brp914
post Jan 11 2006, 08:33 PM
Unregistered
I used a hammer type impact driver with success. btw, pure iodine?! Iodine is a crystalline solid. what the ?
flesburg
post Jan 11 2006, 08:45 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) with brp914.
One of the handiest tool I have is a hand held impact driver, which can be fitted with various bits (flat and phillips screwdrivers and even allen sockets). You position it and twist the body in the direction you want it to move and strike the plunger on the end with a hammer. You may break the screw or bolt, but will not strip it out.
Mine is about a 25 year old Craftsman.
GWN7
post Jan 11 2006, 09:29 PM
King of Road Trips
QUOTE (flesburg @ Jan 11 2006, 06:45 PM)
Yep, I've got one too....works good
VaccaRabite
post Jan 11 2006, 09:52 PM
En Garde!
QUOTE (Dave_Darling @ Jan 10 2006, 07:54 PM)
--DD
Using the right sized screw driver is very important. If you have them, for slotted screws use hollow ground screwdrivers. Much more surface contact for the head of the screw, meaning more grip and less chance of slipping out.
Zach
rjames
post Jan 12 2006, 10:21 AM
I'm made of metal
Unfortunately they looked like a wrench was taken to them before and a couple of them are really chewed up. Hope I don't have to drill them out.
I like the idea of an impact driver....nothing like a good reason to buy a new tool! (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
- Lo-Fi Version Time is now: 20th May 2024 - 10:41 AM
