911 brakes upgrade |
rivs914 |
Jan 10 2006, 10:24 PM
Newbie Group: Members Posts: 11 Joined: 27-September 03 From: sorel, QC Member No.: 1,204 |
Hi!
I've installed 19mm master cylinder with 911 caliper (coming from '69-78 911 I guess) and 911 rotors on my 914. Which size of brake lines do I need to use? Same as 914 OE ones? Anybody have some experience with this modif? Also, is the rear proportionnal valve still needed? Thanks guys |
Bleyseng |
Jan 10 2006, 10:43 PM
Replace the old rubber or SS lines with new ones. I went to a VW Parts store that had short steel brake lines with the correct fittings that I bent carefully to go from the rubber line to the caliper. Was pretty easy to do, just go slow so you don't crimp the new steel line.
see crappy pic (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Attached image(s) |
davep |
Jan 11 2006, 09:44 AM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes, many of us have gone this route, some of us 20 years ago. Other than replacing all the lines, as has been suggested, with stock replacements, there is not much else you need to do. Some of us have also gone to vented rear rotors as well, but it really depends on if you have enough horsepower to require that.
rivs914 |
Jan 11 2006, 12:00 PM
Thanks for your advise.
I will replace all the lines (rubber and steel lines) since there are removed from the car. What is about the proportionnal valve in rear? Did you keep it? |
Eric_Shea |
Jan 11 2006, 12:50 PM
I would ditch the P-Valve with the system you mentioned.
E. |
70Sixter |
Jan 11 2006, 04:19 PM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) With the big brakes up front doing most of the work the valve is not needed. |
Lo-Fi Version | Time is now: 11th May 2024 - 09:21 AM |
