> To light for you racer boy, SCCA Stuck it to me good.
Joe Ricard
post Jan 13 2006, 06:21 PM
CUMONIWANNARACEU
So I got the red neck racer wieghed today. Good news.... 1905 pounds I was so happy to have just made LAST years limit.
So all of you know they screwed my by making Street Modified 2 seat (SM-2) mid engine cars minimum wieght is now 2100 pounds.
Help me with a recipe to gain pounds but make me faster.
I have fiberglass front bumper. Stock passenger seat, 16lb Sparco drivers seat. no tar on the floor, no engine sound deadening, no back pad just some carpet. PC680 Odessy battery, soon to have Tangerine Header. My wheels tip in at 19 lbs each with 20 lb Hoosiers.
I think a cage is in order as it will put on the pounds and stiffen up the chasis. Whats a autopower cage weigh? Sounds Like I will be needing more power to and maybe better brakes. Stock ones were great in a light car.
I know somebody sell me a big six that'll do it.
d914
post Jan 13 2006, 06:36 PM
mount a 100 lb weight under the passenger seat. Low center of gravity, balance out the side to side, cheap. Moveable to where you need to balance to!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
J P Stein
post Jan 13 2006, 06:39 PM
Irrelevant old fart
The shipping weight of an Autopower cage is 110 lbs.
MattR
Build a nice and beefy cage. You can afford the weight penalty. Unless the rules specify, make sure to pick up your suspension points. Next step is to build a ballast box. If you still come in way under weight you can fill the longs with lead shot and expanding foam. Those tips should be good up to 2500 lbs.
bondo
post Jan 13 2006, 06:47 PM
Drop in a V8! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
(yes, I know that would significantly change what class you were in)
I like the big weight down low. It's the best place to put weight, and you can tailor it to meet the minimum exactly. Get it really close, and tape pennies to it throughout the season to compensate for tire wear (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
redshift
post Jan 13 2006, 06:59 PM
Bless the Hell out of you!
Fill your tiars with water.
M
Mueller
post Jan 13 2006, 07:34 PM
914 Freak!
install a cage........the increase in chassis` stiffness and suspension responsiveness (is that word?? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) will amaze you and make you wonder what took you so long to do a full cage (IMG:http://www.914world.com/bbs2/html/emoticons/MDB2.gif)
alpha434
post Jan 13 2006, 07:50 PM
My member number is no coincidence.
a cage weighs approximately 1 pound per foot length for standard regulation diameter (can't think of it off the top of my head) mild steel. Thats a very close approximately- next to a 15th of a pound off. Plus a few extra grams at each weld.
So you've got one hundred and ninety five feet of rollcage to work with.
Stiffening the sides and across the firewall first. Keep low center of gravity. Put some extra weight on the passenger side. That'll help a little. And then go to weld on stiffening kits and such.
"Positive weight theory" extra weight to make you faster- has to be exponentially better than the acceleration and cornering ability you're losing with the added weight.
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
lapuwali
post Jan 13 2006, 07:57 PM
Not another one!
Put in an Engman stiffening kit AND a cage. Add big-ass 911 vented rotors. Add in sound deadening and give your ears a rest. 200lbs is a lot of weight to add back, so don't throw it all at lead bars.
Mueller
post Jan 13 2006, 08:04 PM
914 Freak!
QUOTE (alpha434 @ Jan 13 2006, 06:50 PM)
1.50 x .095 wall DOM is 1.426 pounds per ft. and is the norm size for lighter weight cars........
bondo
post Jan 13 2006, 08:15 PM
Theoretically there could be a point where extra weight down low would help you.. Imagine a weightless car with a 2000 lb targa top.. it would be very unstable. Even though you'd be doubling the weight, I bet your autocross times would go down if you installed a 2000 lb carpet set.
Allan
post Jan 13 2006, 08:20 PM
Teenerless Weenie
Late model doors and '75-'76 bumpers. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
J P Stein
post Jan 13 2006, 08:24 PM
Irrelevant old fart
Actually, I wouldn't add weight.....I'd take more out & head to a different class.
drew365
post Jan 13 2006, 09:34 PM
These are the good old days!
QUOTE (J P Stein @ Jan 13 2006, 07:24 PM)
Sounds like the slippery slope that I'm on.
Foster
post Jan 13 2006, 10:21 PM
Thread Killer
Have my ex wife co-pilot.
She'd bring you up to weight and you'd set record times just to get the race over and get her the hell outta there!! (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
ottox914
post Jan 13 2006, 10:41 PM
The glory that once was.
If you're not going to add the weight with a big 6cyl, I'd do the engman inner long kit, the brad mayeur heavy duty outer long kit, and as much cage as SM2 would allow so far as attachment points.
GWN7
post Jan 13 2006, 11:49 PM
King of Road Trips
What they said......
Also you can add sheet lead (comes in rolls) to the floor to make up any difference.
brant
post Jan 14 2006, 12:26 AM
I wouldn't add a single pound to the brakes...
and the absolute last thing you would want is vented rotors.
your talking about unsprung weight and worse rotational mass...
you certainly don't want this extra weight to eat up your horsepower....
so the cage is good and anything to improve the suspension.
then I'd add weight after that that balanced the car.
get/rent a set of corner balance scales and play with your weights while the car is on scales.
on my old car that ran PCA club racing class I, I had a 45lb piece of 1/2 inch plate steel that was perfectly cut out to fill the entire passenger footwell. It was bolted down per rules and painted black. No one could tell I even had a weight added, yet it helped me make my class minimum.
brant
Joe Ricard
post Jan 14 2006, 07:11 AM
CUMONIWANNARACEU
QUOTE (Foster @ Jan 13 2006, 08:21 PM)
Iv'e been holding auditions for a trunk monkey. or Racer chic that knows how to change tires. Must be hot looking and will wear thong in grid. (so as to distract the other drivers). But any girl close to 195 don't look good in a thong. hey maybe to of them little NOPI hotties they can't go over 95 pounds a piece. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
JP I was looking at Prepared . Geesh means I got to go get 7" rims max for F prepared. So much for my diamond steelies. What class do you run in for SCCA?
Autocross is supposed to be relatively inexpensive. Ha !!! I thing changing rules is fixing that.
Maybe I should just take the step to DE's and stuff I'm pretty much set up for it. and it will take all my money too.
I keep thinking a 125 shifter Kart would be cool. and leave the teener on the street as a look a like racer.
redshift
post Jan 14 2006, 07:52 AM
Hmmm... I may not be as hot as you'd like, but I can guarantee distraction... in a thong...
M
- Lo-Fi Version Time is now: 19th September 2026 - 06:52 AM
