Can anyone ID this front bar? |
Porsche Rescue |
Aug 28 2003, 09:24 PM
Starting to work on my latest project, a neglected but sound six I got on Ebay. No apparent rust but has AC which made for a couple of holes in the sheet metal.
Has an aftermarket front bar. I am only familiar with factory bars. The drop links are separated but do not appear broken. Looks like they use some sort of turn buckle device which is missing. Where can I get the missing pieces? Or should I just pull it and start over? |
Porsche Rescue |
Aug 28 2003, 09:27 PM
Forgot the pics.
Porsche Rescue |
Aug 28 2003, 09:28 PM
Another pic of the mystery bar
Porsche Rescue |
Aug 28 2003, 09:30 PM
and another
Steve |
Aug 28 2003, 09:31 PM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
It looks like my 22mm Weltmeister sway bar minus the circlips.
Steve |
ChrisFoley |
Aug 28 2003, 09:38 PM
I am Tangerine Racing Group: Members Posts: 7,924 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Its a Weltmeister. Originally there was a piece of threaded hex bar stock connecting the rod ends. Either PP might have the parts you need.
Steve |
Aug 28 2003, 10:23 PM
I have the same setup.
The standard kit comes with a fixed bottom. Yours is the optional adjustable drop link kit. Performance Products sells the kit for $109.98 The part number is 909970 in there 914 catalog. Pelican also sells the kit. The part number is DL-800 http://www.pelicanparts.com/catalog/shopca...suspen_main.htm I also upgraded mine to the adjustable drop link kit. I have the old non adjustable drop link if you want it. You cannot mix the parts. The diference between the two is you can just twist the barrel (the part your missing) versus removing the drop link to adjust it. Check out the pelican link and you can compare the parts and look at the pictures. Steve |
Steve |
Aug 28 2003, 10:31 PM
Here's a link to the PP site with a picture of the regular drop link.
http://performanceproducts.com/ProductPage...&producttype=20 Steve |
Brad Roberts |
Aug 28 2003, 11:34 PM
Can you shoot pics of the AC ??
Did Howard buy your 1.7 car ?? B |
Porsche Rescue |
Aug 29 2003, 09:12 AM
Steve, thanks. This car will never see a track so I think the standard links would work fine. Not ready to spend $100 plus for adjustable type.
Brad, I am removing the AC. Probably hasn't seen Freon in 20 years. I can shoot the compressor and under dash unit. Compressor is mounted behind the driver and required a notch (well done) in the firewall. Condenser is in trunk with an oil cooler on top! Hole in floor is only about 6"x14" so I can't imagine how the oil cooler gets much air when it has to travel through the AC radiator first! I'll post some shots later today. |
airsix |
Aug 29 2003, 09:40 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
QUOTE(jim9146 @ Aug 29 2003, 07:12 AM) Steve, thanks. This car will never see a track so I think the standard links would work fine. Not ready to spend $100 plus for adjustable type. Have your friendly local machinist cut and tap two pieces of rod for you. Add 4 jam nuts and you're good to go. I bet it wouldn't cost $20. -Ben M. |
Porsche Rescue |
Aug 29 2003, 09:44 AM
Brad, I did not hear from someone named Howard.
I have a deposit on the car from a woman living in Maine (see thread "Fair Price"). She bought a new '71 and kept it until '83 and now wants another. She is near my age (no social security checks yet, but I can see 'em from here) and plans to drive it home 3400 miles! Club members have offered to help out if problems occur. If things go as planned she will be in Oregon on the 9th. I am looking forward to meeting her. I thought I was pretty daring when I drove it 2400 miles to bring it home. |
Steve |
Aug 29 2003, 10:16 AM
I think they sell the barrel nut or barrel tube at Home Depot.
You could try taking one end off and bring it to Home Depot for fitting. Otherwise if your going to the German Auto Fest I will be there on Sunday. I can bring the fixed parts with me. Let me know. Steve |
Porsche Rescue |
Aug 29 2003, 10:30 AM
Steve, I found barrel nuts at local ACE Hardware but they were right hand thread on both ends. I will need left/right, correct?
I will be in Ventura Sat. and Sun., probably leave early afternoon Sunday. |
Pnambic |
Aug 29 2003, 10:36 AM
Honk if you like obscene gestures! Group: Members Posts: 914 Joined: 9-April 03 From: Atlanta, GA Member No.: 546 Region Association: South East States |
QUOTE(jim9146 @ Aug 29 2003, 10:12 AM) Brad, I am removing the AC. Probably hasn't seen Freon in 20 years. I can shoot the compressor and under dash unit. Compressor is mounted behind the driver and required a notch (well done) in the firewall. Condenser is in trunk with an oil cooler on top! Hole in floor is only about 6"x14" so I can't imagine how the oil cooler gets much air when it has to travel through the AC radiator first! I'll post some shots later today. I'm not sure how effective it would be, but running cool air over the oil cooler isn't the only way to cool the oil. The AC condenser can get pretty cold. It could transfer the lower temps to the oil cooler by direct contact. Though I would imagine that the oil cooler would warm the AC condenser more than the condenser would cool the oil cooler. After getting the car up to operating temp, I bet the air coming through the vents wouldn't be all that cold anymore. (IMG:style_emoticons/default/confused24.gif) Anyone else try it? It certainly sounds original. (IMG:style_emoticons/default/huh.gif) |
MarkV |
Aug 29 2003, 11:29 AM
The A/C condensor doesn't get cold. The condensor is the part that removes the heat, it gets hot. The evaporator is the part that gets cold, it is mounted inside the car.
Steve |
Aug 29 2003, 11:32 AM
Your right about the threads.
Call me on my cell phone before or during the fest. 949-637-5645 I will try to show up by 9am. It's a two hour drive from Laguna Niguel. I'm also curious about the 914-6 air conditioner. Did they use the stock air conditioning pulley on the crank? Did they modify the compressor brackets in anyway or is it stock? I have a Euro 3.2 in my 914 with the Richard Johnson mount. My Richard Johnson mount is using a 911 modified cross bar that was used in a non airconditioned 911. So the air conditioning pulley won't fit. Let alone the firewall mods.... Steve |
Pnambic |
Aug 29 2003, 11:40 AM
QUOTE The A/C condensor doesn't get cold. The condensor is the part that removes the heat, it gets hot. The evaporator is the part that gets cold, it is mounted inside the car. yeah...ummm...I knew that. OOPS |
Lo-Fi Version | Time is now: 10th May 2024 - 09:52 AM |
