Wheel Options??? 4-lug, For a stock fendered 914 |
19144jt |
Jan 18 2006, 06:57 PM
Member Group: Members Posts: 176 Joined: 19-September 05 From: Grass Valley, CA Member No.: 4,829 |
What are my options...
I know about the 2.0 wheel and the Riviera. What else is there? Thanks, John |
TROJANMAN |
Jan 18 2006, 07:01 PM
Looks nice in pictures......... Group: Members Posts: 5,267 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
a few more than that. have you tried doing a search on this site?
Aaron Cox |
Jan 18 2006, 07:02 PM
OEM or factory options
fuchs mahles pedrinis steelies (early and late) aftermarket centerline empi 8 spoke riviera's formula vee's westerns randars raiders minilights (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) i know im missing a bunch.... |
Aaron Cox |
Jan 18 2006, 07:04 PM
addendum revolution 17's revolution 5 spokes revolution 8 spokes.... |
Mueller |
Jan 18 2006, 07:05 PM
4 lug wheel thread discussion
there are factory Mahles and factory Pedrinis....these are the same size as the 4-lug Fuchs after that, you go with the cheap 8-spoke Empi knockoffs or the vw bug rivieras or western rims or 4 spoke American Racing(?)or spend the money and get new wheels such as those posted on the thread link above.... supposedly there will be a proper fitting 15x6 rim being brought in from Australia, but from the one picture I saw of them installed on the front of a 914, the rears fitment looks questionable to me.... |
DNHunt |
Jan 18 2006, 07:15 PM
Mueller |
Jan 18 2006, 07:31 PM
forget checking out Tire Rack (actually they might sell the Revolutions still, they did for a while)...or any other of the usual wheel/tire shops, they won't have a listing or will try to sell you VW Bug rims........
for aftermarket rims, "most" people installed the VW offset rims, cheap and easy, but they limit the tire width (in the rear) that one can mount...not a problem 30 years ago when everyone had skinny tires (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) for bone stock fenders, the general rule is no wider than a 7" rim with a 205mm tire....of course offset of the rim greatly affects these numbers....... |
jhadler |
Jan 18 2006, 07:42 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Off-the-shelf new wheels won't work, nobody makes a 4x130 bolt pattern anymore.
If you don't get a set of older wheels (Fuchs, Mahles, Pedrini's etc), then you'll want to look towards custom wheels. If you want it on the cheap, a company like Diamond Raicng Wheels makes good, cheap wheels in nearly any size, and offset you want. If you want lighter, the next step is likely to be something like Circle Wheels. After that, custom Panasports, Revolutions, Weld, Real, CCW, Fikse and so forth will wind up running you at LEAST $1k for a set, if not much more. As for what will fit? Nearly anything under 8" wide can fit up front, lots of room there. In the rear, you're limited. A 7" wheel with jsut the right backspacing will fit, but it'll be snug. And not all cars were built the same. They were handbuilt remember? So while a 205.60-15 may fit back there on a Fuchs on one car, it may not on another. I managed to shoehorn 225/55-14's under the stock fenders on 14x6's a number of years ago. Not ideal, but it worked... -Josh2 |
TravisNeff |
Jan 18 2006, 11:43 PM
Enkei's, but these have a bug offset. With a 205x55 tire, a lot of pulling on the fender to get them to fit with lots of neg camber too.
bernbomb914 |
Jan 19 2006, 12:03 AM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
ATS made in gernany still in production look on internet under ATS wheels
Bernie Attached image(s) |
Foster |
Jan 19 2006, 12:09 AM
Thread Killer Group: Members Posts: 110 Joined: 26-May 05 From: Great Lakes Member No.: 4,151 Region Association: Upper MidWest |
Slight (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
What size tire have you guys with bug offset Rivies been able to fit under your stock fenders? |
mrobin |
Jan 19 2006, 05:00 AM
Member Group: Members Posts: 69 Joined: 1-August 04 From: boynton beach fl Member No.: 2,425 |
I have 195/65/15 on my riveria's and they just barely make it in the rear.
Foster |
Jan 19 2006, 07:02 PM
Thanks, I've got two sets of Rivies and will probably use those (if I ever figure out how to remove those damn jackstands!!) until I can find a set of rims I really like.
Cap'n Krusty |
Jan 19 2006, 07:18 PM
American mags. Best looking wheel to ever be fitted to a 914, IMO. The Cap'n
Aaron Cox |
Jan 19 2006, 07:24 PM
5 lug or 4 lug? the american racing "lemans/libres" are cool looking.... the 5 lug daisy's are cool, along with the 5 lug torque thrust |
Howard |
Jan 19 2006, 07:31 PM
Incontin(g)ent Member Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None |
I like 'em, too, if these are the ones you mean. PO gave me a set when I bought car. Use them for my street tires. But these are VW offset, so 195/65 max.
Markeydoo |
Jan 19 2006, 07:44 PM
??? Group: Members Posts: 246 Joined: 10-April 03 From: Socal Ventura Member No.: 557 Region Association: None |
I also would like to find a 17" or 18" rim that would fit stock fenders. What would the offset be for a stock fender set up?
What is the max width for the front and back tire size with stock fenders. Thanks Mark |
Aaron Cox |
Jan 19 2006, 07:46 PM
i think 17x7 with 36mm offset is what the revolutions are... and they are close. 7" fuchs are a 23mm offset IIRC... so a 36 puts it closer to the center.... |
andys |
Jan 19 2006, 09:03 PM
These are MOMO's. Do they still make them?
Andys Attached image(s) |
Markeydoo |
Jan 20 2006, 11:59 AM
Aaron
Will 7" work for the front and back? Is there a local dealer or person that sells that size wheel for 4 lug? Thanks |
Lo-Fi Version | Time is now: 9th May 2024 - 08:40 AM |
