is it the relay?, low beams |
Hammy |
Jan 20 2006, 05:00 PM
Well I still can't get my low beams to work.
Is the silver box in this picture(not my pic) the low/high relay? Could a faulty one be causing my problems? Everything works correctly except low beams.... Attached image(s) |
SLITS |
Jan 20 2006, 05:15 PM
No it isn't....It's the silver thingy with the red lettering in the lower right hand corner.
And possibly it could (that's what the source of my high beam problem was) |
Hammy |
Jan 20 2006, 07:54 PM
sorry i didn't notice the arrow in the pic (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (borrowed it from another thread) That's the box i meant.
What was your high beam problem? |
SLITS |
Jan 20 2006, 07:59 PM
click for hi and the lights would go out..........
94teener |
Jan 20 2006, 08:03 PM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
Yes, the lower RH side silver relay is the high-low dimmer relay and it is correctly wired (as shown in the picture.) Either you have a bad relay or your Hi-Lo dimmer switch on the steering column is defective. I would bet on the latter.
Phil |
solex |
Jan 20 2006, 08:10 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Yes it is the silver relay that controls the high and low beams (there is a thread on this). You can try to take it apart and clean the contacts. I recently did this but it turned out the be a problem with the relay.
I noticed that if I held the relay in different positions the hi/low beams would work, I replaced the relay and now I do not have a problem. I tried replacing it with a new one but it seems that the new ones do not work, I got a used one with 5 leads two of the leads need to connected for a car w/o driving lights, check my thread on this. Dan |
Hammy |
Jan 20 2006, 09:20 PM
Where exactly is this...? Dan-thanks, I'll check your thread. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
SLITS |
Jan 21 2006, 12:04 AM
The black thingy you pull on to make it go click click click and change from hi to lo to hi. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Hammy |
Jan 21 2006, 12:07 AM
Ah. Well everything was working fine, including low and high beams, until I screwed with the wiring. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) |
SLITS |
Jan 21 2006, 12:14 AM
If it works keep fixing it until it doesn't.
Lo-Fi Version | Time is now: 8th May 2024 - 08:34 PM |
