Hammy
Jan 20 2006, 05:00 PM
Well I still can't get my low beams to work.
Is the silver box in this picture(not my pic) the low/high relay?
Could a faulty one be causing my problems?
Everything works correctly except low beams....
SLITS
Jan 20 2006, 05:15 PM
No it isn't....It's the silver thingy with the red lettering in the lower right hand corner.
And possibly it could (that's what the source of my high beam problem was)
Hammy
Jan 20 2006, 07:54 PM
sorry i didn't notice the arrow in the pic
(borrowed it from another thread) That's the box i meant.
What was your high beam problem?
SLITS
Jan 20 2006, 07:59 PM
click for hi and the lights would go out..........
94teener
Jan 20 2006, 08:03 PM
Yes, the lower RH side silver relay is the high-low dimmer relay and it is correctly wired (as shown in the picture.) Either you have a bad relay or your Hi-Lo dimmer switch on the steering column is defective. I would bet on the latter.
Phil
solex
Jan 20 2006, 08:10 PM
Yes it is the silver relay that controls the high and low beams (there is a thread on this). You can try to take it apart and clean the contacts. I recently did this but it turned out the be a problem with the relay.
I noticed that if I held the relay in different positions the hi/low beams would work, I replaced the relay and now I do not have a problem.
I tried replacing it with a new one but it seems that the new ones do not work, I got a used one with 5 leads two of the leads need to connected for a car w/o driving lights, check my thread on this.
Dan
Hammy
Jan 20 2006, 09:20 PM
QUOTE (94teener @ Jan 20 2006, 06:03 PM) |
or your Hi-Lo dimmer switch on the steering column is defective. I would bet on the latter. |
Where exactly is this...?
Dan-thanks, I'll check your thread.
SLITS
Jan 21 2006, 12:04 AM
QUOTE (Hammy @ Jan 20 2006, 08:20 PM) |
QUOTE (94teener @ Jan 20 2006, 06:03 PM) | or your Hi-Lo dimmer switch on the steering column is defective. I would bet on the latter. |
Dan-thanks, I'll check your thread. |
The black thingy you pull on to make it go click click click and change from hi to lo to hi.
Hammy
Jan 21 2006, 12:07 AM
QUOTE (SLITS @ Jan 20 2006, 10:04 PM) |
QUOTE (Hammy @ Jan 20 2006, 08:20 PM) | QUOTE (94teener @ Jan 20 2006, 06:03 PM) | or your Hi-Lo dimmer switch on the steering column is defective. I would bet on the latter. |
The black thingy you pull on to make it go click click click and change from hi to lo to hi. |
Ah.
Well everything was working fine, including low and high beams, until I screwed with the wiring.
SLITS
Jan 21 2006, 12:14 AM
If it works keep fixing it until it doesn't.
