Will these work? 4 lug to 5 lug?, Rotors and hubs..I'm lost. |
Brotherbob |
Jan 23 2006, 05:09 PM
Lazy Hack Group: Members Posts: 152 Joined: 6-September 05 From: Granbury TX Member No.: 4,756 |
Fellow Teeners I grabbed these up over the weekend in a massive parts buy. One of those all or nothing deals.
? Will these fit the front of my 4 lug teener by simply using the entire assy? They are kinda nasty so I didnt find a part number but one is in the parts vat now..... I have absolutely no idea about the conversion but thought these might get me there? I bought a bunch of wheels and stuff this weekend . I have been digging through boxes all night. lots of type 1 and 2 parts some P-car too. Wasnt ready to start the 4 to 5 lug deal, but one of those deals where you get it while the gettin' is good. (IMG:http://www.914world.com/bbs2/html/emoticons/givemebeer.gif) Attached image(s) |
Brotherbob |
Jan 23 2006, 05:10 PM
inside
Aaron Cox |
simply NO
not without using 911 struts.... |
Jeroen |
Jan 23 2006, 05:14 PM
you also need to check if they are early or late 911 hubs
Brotherbob |
Party pooper! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
So I guess they are 911? Didnt I see someone grinding the outside edge to fit ? 911 hummm, I grabbed the spindles too? So what parts does a fella look for ? Just 5 lug 914? Or are there some options.... |
Mueller |
Jan 23 2006, 05:17 PM
if you have the struts that match the hubs, then they'll fit the a-arms of the 914....depending on the year, you might have to buy new ball joints....(one style uses a pin, the other style used a bolt)
are those vented or solid? you'll need the brakes from the same assembly...... |
Mueller |
Jan 23 2006, 05:19 PM
ignore the "grinding" post....he was mixing parts that are not designed to be matched up......his setup "should" work, but there are better ways to do it (just use stock components that bolt together) |
Lo-Fi Version | Time is now: 8th May 2024 - 11:53 PM |
