fuel leak, found it finally |
robby750 |
Jan 23 2006, 07:21 PM
Senior Member Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States |
I have been smelling fuel for a while now and finally decided to pull the fuel tank after pinpointing the source somewhere above pedal cluster. It was a lot easier than I expected and did it without an assistant. Ran the tank very low and then siphoned off the last 2 gallons (gasoline tastes terrible). Found the leak at the fuel filter line or maybe the filter itself. While I'm in there I will replace all the windshield washer lines which have leaked since I've owned the car. Also, the drain hoses from the fresh air box were full of holes and I have enough left over from a roll I bought from Pelican that I needed for the engine drain tray. Here are some pics:
robby750 |
Jan 23 2006, 07:23 PM
Got these Rhino Ramps at Sears the other day. Very handy!
robby750 |
Jan 23 2006, 07:25 PM
Here is the drain hose.
robby750 |
And the new one.
robby750 |
Jan 23 2006, 07:26 PM
Garage artwork.
type47 |
Jan 23 2006, 07:27 PM
next time you post a pix, would you mind putting the hood down? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
type47 |
whoa, posted too quick....
Allan |
Jan 23 2006, 07:32 PM
Pelican sells that hose in a roll? I gotta ask more questions the next time I talk to Glen... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
robby750 |
Jan 23 2006, 07:35 PM
Yeah, I ordered some for the engine drain and it came in enough length to do everything. Price wasn't too bad as I recall. It's silver colored instead of black though.
Lo-Fi Version | Time is now: 9th May 2024 - 02:23 AM |
