front brake hose, end of hose fitting too small for clamp |
Mickeyb |
Jan 28 2006, 07:11 PM
What addiction... Group: Members Posts: 38 Joined: 13-November 05 From: Hopewell, VA Member No.: 5,121 |
I ordered new brake hoses from Pelican and was going to install them today. The problem is that one end of the hose is very small and will not lock in with the clamp. Any ideas?
jim912928 |
Jan 28 2006, 07:36 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
hmmm...looks like the ends that hook into my 911.
davep |
Jan 28 2006, 07:53 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Look like the wrong hose, which one did you order.
What year are the struts on the car? |
Mickeyb |
Jan 28 2006, 08:14 PM
Thanks for your quick response to my question. According to the PO they are the original struts. The part number on my receipt is 901-355-632-01 and the tag on the bag it was in has the same part number. But the old hose has the larger ends for the clamp on both ends. The new hose only has one large end for the clamp. Thanks
double-a |
Jan 28 2006, 08:24 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
hm, this sounds familiar... i recently ordered a complete set of rubber brake lines from pelican for my '75, only to find that the two fronts they had shipped were the early (70-72) style. if you haven't run brake fluid through them, they might take them back in exchange. or if you've got to get your car on the road, i found some good ones at the local bug shop.
~a |
Lo-Fi Version | Time is now: 27th May 2024 - 11:16 PM |
