Mickeyb
Jan 28 2006, 07:11 PM
I ordered new brake hoses from Pelican and was going to install them today. The problem is that one end of the hose is very small and will not lock in with the clamp. Any ideas?
jim912928
Jan 28 2006, 07:36 PM
hmmm...looks like the ends that hook into my 911.
davep
Jan 28 2006, 07:53 PM
Look like the wrong hose, which one did you order.
What year are the struts on the car?
Mickeyb
Jan 28 2006, 08:14 PM
Thanks for your quick response to my question. According to the PO they are the original struts. The part number on my receipt is 901-355-632-01 and the tag on the bag it was in has the same part number. But the old hose has the larger ends for the clamp on both ends. The new hose only has one large end for the clamp. Thanks
double-a
Jan 28 2006, 08:24 PM
hm, this sounds familiar... i recently ordered a complete set of rubber brake lines from pelican for my '75, only to find that the two fronts they had shipped were the early (70-72) style. if you haven't run brake fluid through them, they might take them back in exchange. or if you've got to get your car on the road, i found some good ones at the local bug shop.
~a
