Oxidation Removal, Meguiars #2 works! |
Bruce Allert |
Jan 30 2006, 11:42 PM
Hellions asleep Group: Members Posts: 3,289 Joined: 19-March 03 From: Eagle Creek, Orygun Member No.: 441 Region Association: Pacific Northwest |
Did a search this afternoon for restoring oxidized paint.
Found a thread listing the Meguiars web site (http://www.meguiars.com/) & had some good reading. While picking up some Kendal's 20/50 for the 914's oil change I grabed a bottle of #2 Meguiars cleaner. The pic shows what just 2 minutes did rubbing by hand. I was amazed that the old oxidized paint came to life (IMG:http://www.914world.com/bbs2/html/emoticons/thumb3d.gif) BTW, it's the real dark spot on the trunk (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Anyone have another good oxidizing removal product to mention ? ......b Attached image(s) |
sixnotfour |
Jan 31 2006, 12:08 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
random orbitable sander/buffer with a foam pad makes it easier.
sweat equity |
Bruce Allert |
Jan 31 2006, 12:16 AM
I was looking for one of those today. ran outta time.
Bet that makes a quick job out of it, huh? .........b |
sixnotfour |
Jan 31 2006, 12:28 AM
Kinda exspensive but something to look at their process for ideas.
speedshine and clay block makes it smooth removes embedded dirt etc. good first step. http://www.griotsgarage.com/search.jsp?sea...earchtext=11119 |
redshift |
Jan 31 2006, 12:36 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Shining is fun.... don't forget that people buying that kit, also bought the retractable ceiling thing. hah M |
markb |
Jan 31 2006, 12:42 AM
Marcie (my resident expert) says in this order, "clay, clean, polish, then wax" You can also go to the Meguiars website, put in where you live, and it'll tell you exactly which products to use to combat the conditions of your area.
Sounds like a lotta work to me. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
914-8 |
Jan 31 2006, 01:31 AM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
That paint is looking pretty pasty.
I'd lightly wet sand it with 2000, at least on the horizontal surfaces (vert surfaces probably don't need it). Then, polish with a random orbital in this order: 1. Meguire's Heavy Cut cleaner using burgandy pad. 2. Meguire's Light Cut cleaner using yellow pad. 3. Meguire's Swirl Remover using tan pad. 4. Your favorite wax using tan pad. All of that would take the good part of a Saturday, but your car would look absolutely brand new, even under the harshest lighting conditions (flourescent light, early morning sun, etc). |
Bruce Allert |
Jan 31 2006, 12:16 PM
When wet sanding would this be by hand? Also, would it be in straight paths (all the same direction)or in circles? .......b |
Kargeek |
Jan 31 2006, 01:05 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
Never sand in circles...always sand in stright lines.
Some detailers claim that polishing in circles will do the same so, polish in stright line especially on dark colored paints. Wet sand by hand using water with a drop of soap- helps to miminize loading of the 2000 sandpaper. DH |
Lo-Fi Version | Time is now: 14th May 2024 - 09:13 PM |
