trailing arm comparison, boxster versus 914 |
Jan 31 2006, 12:39 PM
Has anyone done a comparison of the 914 versus boxster trailing arm comparison?
Any pics?? Specifically looking for pics of a boxster trailing arm. Rich |
ClayPerrine |
Jan 31 2006, 01:06 PM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Boxster doesn't have a trailing arm.
ClayPerrine |
Jan 31 2006, 01:09 PM
ClayPerrine |
Jan 31 2006, 01:11 PM
Mueller |
Jan 31 2006, 01:50 PM
it's considered a modified Macferson strut suspension from what I've read...there is one link per side that attaches to the lower arm that limits fore and aft movement...
unless they've changed thier minds, there are 2 members currently attempting to install a Boxster rear suspension in thier 914's |
Jan 31 2006, 02:20 PM
ok, shows that I have never been under a boxster.
There must be some sort of sub-frame assembly under the tranny for that to work. So, you need to remove that sub frame to remove the engine?? Rich |
Mueller |
Jan 31 2006, 02:22 PM
it looks like 6 to 8 bolts to remove the entire rear suspension...same goes for the front.... you wanna send me some pictures (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Jan 31 2006, 02:25 PM
you got time?
I got some ideas how to fix it...just need to make sure you got the bandwidth... Rich |
Mueller |
Jan 31 2006, 02:26 PM
i'm bound and determined to achieve my goal of "one new product or more a month"....ummmm, starting next month, hahahaha |
bryanc |
Jan 31 2006, 02:48 PM
Member Group: Members Posts: 321 Joined: 9-August 04 From: San Antonio, Tx Member No.: 2,495 Region Association: Southwest Region |
There is a subframe that most of the suspension links bolt to. The fore/aft links bolt up beside the engine like 914 trailing arms do.
The subframe holds the back half of the tranny and connects to the chassis above and via the aluminum bars that run under the motor. IIRC, the subframe is similar to the frame used on 996/997 models, just swapped around. There are only a few bolts holding the thing together. I recently changed the inner CV joint boots on my Boxster and had to pull lots of the suspension pieces to get the CV off. |
Lo-Fi Version | Time is now: 14th May 2024 - 09:53 AM |
