How hot does exhaust get? |
rick 918-S |
Jan 31 2006, 11:52 PM
Hey nice rack! -Celette Group: Members Posts: 20,456 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Anyone ever hit the exhaust with a temp gun. How hot do exhaust pipes get? I'm asking because I'm thinking of having my exhaust pipes powder coated. Not the manifolds, just the pipes.
Joe Ricard |
Feb 1 2006, 06:24 AM
Just get them jet hot coated. Sort of the same process just higher temp.
I would imagine as shourt as your pipes are from the thumpin V-8 they will be damn hot. Like aren't they going to be about the length of where the CAT would sit on the 928? |
redshift |
Feb 1 2006, 06:32 AM
Ron said 1600f in the elbows, and sure enough, 1200f paint just turns to ash in the elbows of my Triad.
Ouch! M |
BIGKAT_83 |
Feb 1 2006, 06:39 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Eastwood sells a HI-TEMP powder coating for headers.Seems to work better than any rattle can Hi-temp paint I've used.
Bob (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
rick 918-S |
Feb 1 2006, 07:54 AM
I fried Eastwoods hi-temp paint off my cast manifolds. Turned to ash then to rust. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) I was going to get my manifolds Jet-Hot coated but I'm looking for a lower cost way to coat my pipes. I'm working on a heat exchanger idea. There will be considerable welding involved. Unless I build them in stainless they'll rust out up here in a year just sitting in the garage. I need a low cost solution.
BIGKAT_83 |
Feb 1 2006, 08:01 AM
I used the eastwood brush on paint at first too. This lasted less than a week before it burnt off.
This is powder coat that has been on for 2 years now and still pretty good. (IMG:http://www.914world.com/bbs2/uploads/blog-1137630764.jpg) (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Bob |
Joe Ricard |
Feb 1 2006, 08:03 AM
Ok I don't get it. why would you make heat exchangers if you got hot water going through the car.
rick 918-S |
Feb 1 2006, 08:18 AM
I have the stock flapper doors, the stock heat worked well with the 1.7, adding a water type heat exchanger is alot of work, the re-invented heating system may not work as well as the stock ducting, more clutter in the engine compartment, more of a change of adding a place for air to be trapped in the system, one less hose connection to worry about developing a leak, the list goes on. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:17 PM |
