rick 918-S
Jan 31 2006, 11:52 PM
Anyone ever hit the exhaust with a temp gun. How hot do exhaust pipes get? I'm asking because I'm thinking of having my exhaust pipes powder coated. Not the manifolds, just the pipes.
Joe Ricard
Feb 1 2006, 06:24 AM
Just get them jet hot coated. Sort of the same process just higher temp.
I would imagine as shourt as your pipes are from the thumpin V-8 they will be damn hot. Like aren't they going to be about the length of where the CAT would sit on the 928?
redshift
Feb 1 2006, 06:32 AM
Ron said 1600f in the elbows, and sure enough, 1200f paint just turns to ash in the elbows of my Triad.
Ouch!
M
BIGKAT_83
Feb 1 2006, 06:39 AM
Eastwood sells a HI-TEMP powder coating for headers.Seems to work better than any rattle can Hi-temp paint I've used.
Bob
rick 918-S
Feb 1 2006, 07:54 AM
I fried Eastwoods hi-temp paint off my cast manifolds. Turned to ash then to rust.
I was going to get my manifolds Jet-Hot coated but I'm looking for a lower cost way to coat my pipes. I'm working on a heat exchanger idea. There will be considerable welding involved. Unless I build them in stainless they'll rust out up here in a year just sitting in the garage. I need a low cost solution.
BIGKAT_83
Feb 1 2006, 08:01 AM
I used the eastwood brush on paint at first too. This lasted less than a week before it burnt off.
This is powder coat that has been on for 2 years now and still pretty good.
Bob
Joe Ricard
Feb 1 2006, 08:03 AM
Ok I don't get it. why would you make heat exchangers if you got hot water going through the car.
rick 918-S
Feb 1 2006, 08:18 AM
QUOTE (Joe Ricard @ Feb 1 2006, 06:03 AM) |
Ok I don't get it. why would you make heat exchangers if you got hot water going through the car. |
I have the stock flapper doors, the stock heat worked well with the 1.7, adding a water type heat exchanger is alot of work, the re-invented heating system may not work as well as the stock ducting, more clutter in the engine compartment, more of a change of adding a place for air to be trapped in the system, one less hose connection to worry about developing a leak, the list goes on.
