Ty's 914 project... |
ty914 |
May 3 2006, 05:51 PM
Member Group: Members Posts: 87 Joined: 23-August 05 From: Memphis, Tennessee USA Member No.: 4,646 |
last one until tomorrow...
ty914 |
May 23 2006, 07:48 AM
Undercoating is DONE!!! Started sanding the body down to prep for paint...
ty914 |
May 23 2006, 07:53 AM
next...
ty914 |
May 23 2006, 07:54 AM
next...
ty914 |
May 23 2006, 07:55 AM
started work on the suspention...to get this thing back on the ground...
ty914 |
May 23 2006, 07:56 AM
Thanks to Kelly for getting me a A-Arm...I didn't see how bad mine was until yours arrived...THANKS!
ty914 |
May 23 2006, 07:58 AM
Also NEW Bilstien all around and a few other new parts...starting to feel progress. My Dad is flying in from Spokane, WA...aka Spokompton, Spokanistan, Spoklahoma...you get the picture. We are going to work on this for the next week sun up till sun down and see if we can get it ready for the paint shop!
Rusty |
May 24 2006, 02:42 AM
Nice work... you've really accomplished a lot. You should be very proud.
What kind of paint and primer system are you using? -Rusty (IMG:style_emoticons/default/smoke.gif) |
ty914 |
May 24 2006, 07:08 AM
Thanks...
For the underside I started with Dupont Veriprime (recommended from a fellow member). Then reapplied the undercoating with U-POL Gravitex Plus. www.AutoBodyDepot.com has everything I have needed. U-POL looks and feels the same as Wurth SKS but is less than 1/2 the price. I ordered 2 lt. and the application gun as a package for $25. For the paint I am using PPG. I painted my last 911 with Deltron (DAU Acrylic Urethane) so I plan on doing the same for the 914. The base I am using PPG K38 primer. All of the P Sheets for PPG I printed off of www.tricitypaint.com/docs.html That gives all the compatible products and spect for the application. The only thing I have not decided on is if I want to use DELGLO DAU 82. It is a clear that can be mixed 1:1 or applied as final coats to the paint. I am going to swing by the supply shop and ask. I will see how that goes they don't like dealing with D.Y.S. people and they are the only ones that sell PPG. My Dad flies in today so I bet we will get a lot done. I might have found a body shop that will let me "rent" the spray both on the weekend after hours. I need to pick what COLOR I am going to paint this thing... Is there a BAD color out there on the 914??? Every color I look at looks good... T |
ty914 |
Sep 11 2006, 12:29 PM
Make some progress through the heat!
ty914 |
Time to PRIME...in the garage.
ty914 |
Sep 11 2006, 12:30 PM
ty914 |
My Dad flew in from Spoklahoma (Spokane, WA) to help me out for a few days...I think the temp was about 105. Prime done for now...POR15 time.
ty914 |
Sep 11 2006, 12:31 PM
ty914 |
After the POR15...I sprayed UPOL undercoating in the floor of the tunks, engine bay, and fuel compartment.
ty914 |
Sep 11 2006, 12:32 PM
Oh yea...and the inside with UPOL.
ty914 |
ty914 |
ty914 |
Sep 11 2006, 12:33 PM
ty914 |
Sep 11 2006, 12:34 PM
2nd coat of PRIMER over everything this time...getting closer to paint!
Lo-Fi Version | Time is now: 28th May 2024 - 02:21 PM |
