> weber tuning, questions
r_towle
post Feb 6 2006, 03:41 PM
Post #21
Custom Member
ok,
So I have one rich and one perfect plug on one side...
I will use the idle mixture screw to adjust this condition...
What is the air bypass screw for, where do you guys set it, and how does it change the way the carb tunes??
I was having some sooty exhaust, so I checked the floats..perfect..if not just a tad lean...11mm which is ok with me...
Rich
r_towle   weber tuning   Feb 6 2006, 03:41 PM
TimT   use the idle air bypass screw to adjust the airflo...   Feb 6 2006, 03:54 PM
lapuwali   The air bypass screws are there to balance the air...   Feb 6 2006, 03:55 PM
MarkV   The air bypass screws add air so you can get each ...   Feb 6 2006, 03:57 PM
r_towle     Feb 6 2006, 04:02 PM
TimT   Once you have the airflow balanced play with the m...   Feb 6 2006, 04:05 PM
hmeeder   Rich; I was going through all of this just a we...   Feb 6 2006, 04:07 PM
r_towle   thanx...that will work... I hope...kinda hard get...   Feb 6 2006, 04:09 PM
r_towle     Feb 6 2006, 04:14 PM
TimT   Ive been tuning Webers 3bbl weber for over 25 yea...   Feb 6 2006, 04:25 PM
MarkV   Coughing through the carb means that cylinder is l...   Feb 6 2006, 04:39 PM
9146986   I've copied this from a post I made in Sept 04...   Feb 6 2006, 04:56 PM
lapuwali   When adjusting the idle mixture screws, go slow. ...   Feb 6 2006, 05:08 PM
rhodyguy   as stated. initially set all 4 of the bypass the s...   Feb 7 2006, 10:03 AM
r_towle   I got it. See, I am hearing that the air bypass s...   Feb 7 2006, 10:10 AM
TimT     Feb 7 2006, 10:35 AM
TimT   Oh and when you install the linkage, dont touch th...   Feb 7 2006, 10:37 AM
yarin   megasquirt megasquirt megasquirt
- Lo-Fi Version Time is now: 4th July 2025 - 01:56 PM
