Bending Brake lines, for fuel line use |
yarin |
Feb 9 2006, 11:14 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I bought 3/8" and 5/16" (2 each 60" and 40") brake lines to use for replacing my plastic fuel lines. I'm following the pelican fuel line replacement how to. However i'd rather not use a 90 deg bend and increase the # of fitting in the system.
Can I just bend the brake lines using proper tooling? The auto part store sells one for around $30. With this significantly reduce the flow? Has anyone here followed the pelican how to? Is the 60" line long enough to feed through the tunnel and leave 2-3" at the firewall side for this 90 deg bend? Thanks |
Lo-Fi Version | Time is now: 18th May 2024 - 03:04 AM |
