windshield removal |
tdsmoonchild |
Feb 15 2006, 06:22 AM
Terry Group: Members Posts: 197 Joined: 18-January 06 From: Duncanville,TX Member No.: 5,431 |
I need to remove the windshield to prep that area. What is the safe/easiest way? Seem to remember in the old days talk of suction cups and piano wire.................
rhodyguy |
Feb 15 2006, 08:10 AM
i asked this same thing yest. scroll down. i will be writing a " how to ruin nice aluminum trim and break a perfectly good windshield, because i tried to remove it when it was too cold" thread in the near future. i plan on getting one of chris folley's groovy trim removal tools.
k |
Rob K |
Feb 15 2006, 08:36 AM
Newbie Group: Members Posts: 22 Joined: 25-October 05 From: Overland Park, Kansas Member No.: 5,003 |
I just used a n old flexible 1 inch putty knife. When I had seperated a section, I would put thin wooden blocks under it to prevent it from re-gluing itself. It took a couple hours. Don't get in a hurry. If you put it in a bind, it will break. That butyl rubber is the stickyest stuff I have ever seen.
Good Luck Rob |
mrdezyne |
Feb 15 2006, 08:47 AM
Now on larger rolling jack stands! Group: Members Posts: 468 Joined: 31-July 05 From: Tulsa, OK Member No.: 4,510 |
However if you get lucky and your seal is old and crappy like mine was, you will find that after you take the trim off, the windsheild will already be loose on one side and the other side will almost fall out with the slightest bit of pressure.... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) I wasn't ready for it to come out, but appearantly it was....
tdsmoonchild |
Feb 15 2006, 08:55 AM
Mine seems pretty stuck! |
aircooledboy |
Feb 15 2006, 04:04 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
Hey boys,
Wrote this post long ago: Windshield removal info PM me if you need to know more. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Chris |
Lo-Fi Version | Time is now: 18th May 2024 - 05:16 AM |
