how do you test a fuel level sender? |
GaroldShaffer |
Feb 15 2006, 07:07 AM
You bought another 914? Group: Benefactors Posts: 7,622 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
So in my statsh of parts I found a fuel level sending unit, it looks in good shape but how do you test it out of the car?
lapuwali |
Feb 15 2006, 01:08 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
If you have a multi-meter, measuring ohms across two of the pins should give you infinite resistance with the sender held upside down (float at the "top"), and 0 resistance with the sender held upright. This is the light switch. Two other pins will give you a variable resistance from 5-10ohms with the float at the top, and 70-90 ohms with the float at the bottom.
There's a description of which pins to what in my blog. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:22 AM |
