Minor update on the 3.3 turbo (No avatar content), Finally got the rear frame done. |
Mugs914 |
Feb 15 2006, 07:03 PM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
The trans mount part of the tube frame is finally done. At this point a lot of the remaining sheet metal will be going away and being replaced by tubes to support wings, decklid, etc..
(IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) And so it goes... Pics: Attached image(s) |
Mugs914 |
Feb 15 2006, 07:06 PM
still have to fab up the actual mount that bolts to the tranny...
Mugs914 |
Feb 15 2006, 07:09 PM
Another angle...
LvSteveH |
Feb 15 2006, 07:12 PM
I put the Poor in Porsche Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 |
Nice work! It looks like it's too late, but there is a shop that does a side shift conversion for the G50, and the rod comes out of the trans at about the middle on the driver's side, very clean, gets you about 5" shorter (length of the rear shift rod). Great project, I look forward to seeing the progress.
Mugs914 |
Rear shot. The final rear ride height will be a few inches lower...
Mugs914 |
Feb 15 2006, 07:15 PM
One more interior shot. Finished up the dead pedal, left leg support and a few other details...
Sideways |
Feb 15 2006, 07:20 PM
Member Group: Members Posts: 119 Joined: 18-October 05 From: Calgary, AB, Canada Member No.: 4,969 |
Where did you get that cable shifter from?
Did you machine the oil galleries inside the transmission case before you inverted it? |
byndbad914 |
Feb 15 2006, 07:40 PM
shoehorn and some butter - it fits Group: Members Posts: 1,547 Joined: 23-January 06 From: Broomfield, CO Member No.: 5,463 Region Association: None |
Holy crap, I thought my 930 trans was bad because the shift linkage just kisses the inner rear bumper panel. I knew those G50 variations were longer, but that really hangs out there.
I am constant fear of getting bumped at the rear (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) That would be about a $5K 5mph crash (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) So since I am doing a full tube car, I am moving the firewall forward a few more inches and moving everything forward for 2 reasons... the first is the shift shaft fear, the other is to better redistribute my weight forward (I have a V8 car so a bit different, but I would still think you may be a little tail heavy in weight distribution). Any particular reason you didn't move the engine/trans forward a bit to bring the linkage "in house" so to say? What are you setting your final ride height to? Tim |
Mugs914 |
Feb 15 2006, 07:56 PM
The cable shifter came from Patrick Motorsports in Phoenix. They also converted the G50 to run inverted, galleries, plugs and all... |
Aaron Cox |
Feb 15 2006, 08:04 PM
mike... absolutely killer!!!!
come up to joes bbq saturday! |
Mugs914 |
Feb 15 2006, 08:29 PM
Oh yeah, the G50/52s are L-O-N-G! As you see it, the engine is only about an inch farther forward than in my 3.0 road car, but it will move forward a bit more when the mounts are finished. It still leaves the shift rod really close to the rear bodywork. That rear tow hook/bumper is to take the hit instead of the trans. As for weight distribution, the fuel cell, oil tank and coolers all live up front, so I'm not too worried about it balancing properly. It'll go on the scales when I place the major components so I'll have a good idea about where things need to go. The initial ride height will be somewhere around 3" up front and 3.5" in the rear. It may actually go higher than that though. This car will have full underbody ground effects, so ride height will be determined by testing, ultimately. |
TravisNeff |
Feb 15 2006, 09:21 PM
Damn that G50 is long, at least you you get a built in tow hook in the back!
Mugs914 |
Feb 16 2006, 12:09 AM
Thanks! I'm puttin' my name in for Joe's, though the "boss" might have something planned already... (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) What time do things get started and how late do they go? Or should I say how long will everyone be coherent? (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/drunk.gif) |
db9146 |
Feb 16 2006, 03:42 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Mike,
How does it shift compared to a 901 or a 915? Have you lived with it very long (reliability)? |
sixnotfour |
Feb 16 2006, 04:00 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Could you give us some more info ? contact? Thanks |
LvSteveH |
Feb 16 2006, 04:15 PM
California Motorsports does the conversinon. They also do the ring gear flips for the 930 Turbo trans. Nice place. Attached image(s) |
sixnotfour |
Feb 16 2006, 07:09 PM
Wow thanks , looks like they know what they are doing. (IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif)
Mugs914 |
Feb 16 2006, 08:29 PM
It's a much shorter throw and much more crisp. My road car has a 901 with a Weltmeister short throw shifter. It's one of the nicest shifting 901s I've driven, and the cable set-up is just as good if not better. In fact I wouldn't hesitate to use a tail shifter 901 with the cables rather than a side shifter. As far as reliability I don't really know, I haven't had it long enough. But the Patrick has been using them for years in both street and race cars without trouble. There is very little to go wrong... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 03:47 AM |
