Easiest way to remove cowl vent grille? |
914-8 |
Feb 16 2006, 03:05 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
Need to remove for paint. The little plastic grille on the cowl between the windshield wipers.
What's the easiest way to get it out? |
mrdezyne |
Feb 16 2006, 04:32 PM
Now on larger rolling jack stands! Group: Members Posts: 468 Joined: 31-July 05 From: Tulsa, OK Member No.: 4,510 |
I think you are talking about the plastic peice under the cowl like this one?
mrdezyne |
Feb 16 2006, 04:33 PM
My 73 didn't have that do-hicky, but you will need to remove this fan and air box to get to that grill I think.....
bondo |
Feb 16 2006, 04:35 PM
The "easy" way is to cut the cowl out with a plasma cutter, and weld it back in afterwards.. whicjh gives you an idea of how much of a pain the "right" way (taking out the air box) is.. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
mrdezyne |
Feb 16 2006, 04:39 PM
True! (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
I guess I should have said that there is NO easy way...... |
736conver |
Feb 16 2006, 04:40 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Cant you just slide some paper strips onto the top of it.
bondo |
Feb 16 2006, 04:49 PM
There's a gasket around it.. if the gasket is still good, it would be difficult. Pretty much every one of those I have seen has been painted.. I think it's fairly standard to just leave it. You might be able to mask it with little oval bits of masking tape, but that would be hard too. |
736conver |
Feb 16 2006, 04:53 PM
bondo |
Feb 16 2006, 04:57 PM
Ooh, I get it.. clever! Might take a couple of overlapping pieces of paper, but it would certainly work.
736conver |
Feb 16 2006, 05:06 PM
Tricky yet so simple. 3X5 cards would work the easiest
914-8 |
Feb 16 2006, 06:23 PM
3x5 cards, slid in from the top, sounds like the way to go.
Now that I think about it, I think that's what I did when I painted my last 914 in my garage 10 years ago. Attached image(s) |
914-8 |
Feb 16 2006, 06:24 PM
Came out nice!
Lo-Fi Version | Time is now: 4th May 2024 - 01:48 AM |
