Engine Drop, What to do with it after it is out? |
Bertus |
Feb 21 2006, 07:06 AM
Member Group: Members Posts: 222 Joined: 2-May 05 From: Lexington, KY Member No.: 4,021 Region Association: South East States |
I am gonna take my engine out this week (been saying that for a couple of weeks now!) and wanted some advice on:
A: how to store it. I don't have an engine stand, I do have a bunch of 2x4s laying around maybe construct something out of those to keep it off the ground. What worked for you? Just leave it on the ground? B: what are some common maintaince issues that should be done on the motor while it is out? Thanks all, I need to get motivated and get this done before warm weather returns! |
Bleyseng |
Feb 21 2006, 07:16 AM
Maintance issues?
Hmm, here's a list of things to do change injector seals change oil cooler seals change fuel lines replace vacuum hoses adjust valves and change valve cover gaskets check the clutch plate or replace check end play on flywheel if bad change oil seal and adjust endplay remove tin/fan and clean everything have tin powdercoating replace front seal etc |
Bertus |
Feb 21 2006, 07:58 AM
Thanks for the suggestions! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
rhodyguy |
Feb 21 2006, 08:07 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
for storing and during the removal, go to home depot and pickup one of their $18 funiture dollys. makes it easy to slide the engine out from underneath the car, you don't kill your back dragging the engine around the garage (you can do it by yourself), and easy to work on the engine. i have 3 of them.
k |
GaroldShaffer |
Feb 21 2006, 08:12 AM
You bought another 914? Group: Benefactors Posts: 7,621 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I bought a set of wheel dollies for rolling around parts cars. I found that one of those works good for holding engines, also look at one of those 4 wheel furniture dollies I have heard they work. Both make it easier to move the engine around if you need to.
Edit damn, I got to type faster roadguy is beat me to it. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Dead Air |
Feb 21 2006, 08:17 AM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
[QUOTE] Ship it to Jake Raby (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
URY914 |
Feb 21 2006, 08:25 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,486 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The furniture dollys are good. Also take some of your 2x4's and make a frame that fits under the bottom of the case. This will raise the engine up a little higher so it is easier to work on. I don't like to support the weight of the engine by blocking up under the heads. If you leave the engines front mounting bar on it, it makes it a lot easier to pick it up. It acts like a big handle to move it by.
P |
jasons |
Feb 21 2006, 08:29 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I would add pushrod tubes and/or seals. If you have any beat up tubes or leaky ones, now is a good time to deal with those. You can't remove some of them while the motor is in the car. The control arm ears are in the way. Also motor mounts and trans mounts. |
lotus_65 |
Feb 21 2006, 08:43 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
why drop the motor? get a chunk of 2x4 and a furniture dolly. i jacked my car almost high enough to walk under, so i had to use the 2x4 to make contact with the motor. but i slid the jack under the dolly first so the motor dropped right down on to it. then i pulled the jack out and rolled the motor out easy as pie. then you'll have a good place to "store" the motor and move it easily too. as far as maintenance, there was a ton of crud between the engine tin and the cylinders on one side. you'd have to pull the heads to get at that area, but it think it meant much warmer running temps on that side. since your in there, rebuild the motor! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Attached image(s) |
Bertus |
Feb 21 2006, 09:03 AM
Lotus65, were you able to get the jack from underneath the dolly after you lowered the engine? Fortunately the engine is really strong not dropping it to work on it specifically, I have hell hole rust issues I need to eradicate! btw is that a Harbour Freight jack stand in your pic, looks just like mine! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
lotus_65 |
Feb 21 2006, 09:13 AM
yep, harbor freight (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
the dolly is a "tool shop" from home depot, but if you get one that is too low, just upsize 2 of the casters or shim them for clearance. i had tons of clearance. i have nothing good to say about hell hole issues! good luck with yours. |
Joe Ricard |
Feb 21 2006, 09:48 AM
I agree with all of the above. Just one thing to add that will make life easier when you get around to doing something with it.
Shove 100.00 dollar bill in each intake port. Put two in the dizzy cap, maybe 3 in the throttle body. years from now when you don't have enough money to do a rebuild you can use this to get the machine work done. |
Bertus |
Feb 21 2006, 10:04 AM
What kind of return on interest can I expect? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Along these lines this car came with a Highfire VI, Mallory Promaster coil, and a Mallory Unilite distributer that are not currently installed. I was thinking of installing this summer. Should I expect headaches? |
Joe Ricard |
Feb 21 2006, 10:15 AM
Nope plug and play. That's what I got on the Red Neck Racer.
Lo-Fi Version | Time is now: 10th May 2024 - 06:31 AM |
