Bertus
Feb 21 2006, 07:06 AM
I am gonna take my engine out this week (been saying that for a couple of weeks now!) and wanted some advice on:
A: how to store it. I don't have an engine stand, I do have a bunch of 2x4s laying around maybe construct something out of those to keep it off the ground. What worked for you? Just leave it on the ground?
B: what are some common maintaince issues that should be done on the motor while it is out?
Thanks all, I need to get motivated and get this done before warm weather returns!
Bleyseng
Feb 21 2006, 07:16 AM
Maintance issues?
Hmm, here's a list of things to do
change injector seals
change oil cooler seals
change fuel lines
replace vacuum hoses
adjust valves and change valve cover gaskets
check the clutch plate or replace
check end play on flywheel if bad change oil seal and adjust endplay
remove tin/fan and clean everything
have tin powdercoating
replace front seal
etc
Bertus
Feb 21 2006, 07:58 AM
QUOTE (Bleyseng @ Feb 21 2006, 05:16 AM) |
Maintance issues?
Hmm, here's a list of things to do change injector seals change oil cooler seals change fuel lines replace vacuum hoses adjust valves and change valve cover gaskets check the clutch plate or replace check end play on flywheel if bad change oil seal and adjust endplay remove tin/fan and clean everything have tin powdercoating replace front seal etc |
Thanks for the suggestions!
rhodyguy
Feb 21 2006, 08:07 AM
for storing and during the removal, go to home depot and pickup one of their $18 funiture dollys. makes it easy to slide the engine out from underneath the car, you don't kill your back dragging the engine around the garage (you can do it by yourself), and easy to work on the engine. i have 3 of them.
k
GaroldShaffer
Feb 21 2006, 08:12 AM
I bought a set of wheel dollies for rolling around parts cars. I found that one of those works good for holding engines, also look at one of those 4 wheel furniture dollies I have heard they work. Both make it easier to move the engine around if you need to.
Edit damn, I got to type faster roadguy is beat me to it.
Dead Air
Feb 21 2006, 08:17 AM
Maintance issues?
[QUOTE]
Ship it to Jake Raby
URY914
Feb 21 2006, 08:25 AM
The furniture dollys are good. Also take some of your 2x4's and make a frame that fits under the bottom of the case. This will raise the engine up a little higher so it is easier to work on. I don't like to support the weight of the engine by blocking up under the heads. If you leave the engines front mounting bar on it, it makes it a lot easier to pick it up. It acts like a big handle to move it by.
P
jasons
Feb 21 2006, 08:29 AM
Maintance issues?
I would add pushrod tubes and/or seals. If you have any beat up tubes or leaky ones, now is a good time to deal with those. You can't remove some of them while the motor is in the car. The control arm ears are in the way.
Also motor mounts and trans mounts.
lotus_65
Feb 21 2006, 08:43 AM
QUOTE (Bertus @ Feb 21 2006, 08:06 AM) |
A: how to store it. I don't have an engine stand, I do have a bunch of 2x4s laying around maybe construct something out of those to keep it off the ground. What worked for you? Just leave it on the ground? |
why drop the motor?
get a chunk of 2x4 and a furniture dolly. i jacked my car almost high enough to walk under, so i had to use the 2x4 to make contact with the motor.
but i slid the jack under the dolly first so the motor dropped right down on to it.
then i pulled the jack out and rolled the motor out easy as pie. then you'll have a good place to "store" the motor and move it easily too.
as far as maintenance, there was a ton of crud between the engine tin and the cylinders on one side. you'd have to pull the heads to get at that area, but it think it meant much warmer running temps on that side.
since your in there, rebuild the motor!
Bertus
Feb 21 2006, 09:03 AM
QUOTE (lotus_65 @ Feb 21 2006, 06:43 AM) |
QUOTE (Bertus @ Feb 21 2006, 08:06 AM) | A: how to store it. I don't have an engine stand, I do have a bunch of 2x4s laying around maybe construct something out of those to keep it off the ground. What worked for you? Just leave it on the ground? |
why drop the motor?
since your in there, rebuild the motor! |
Lotus65,
were you able to get the jack from underneath the dolly after you lowered the engine?
Fortunately the engine is really strong not dropping it to work on it specifically, I have hell hole rust issues I need to eradicate!
btw is that a Harbour Freight jack stand in your pic, looks just like mine!
lotus_65
Feb 21 2006, 09:13 AM
yep, harbor freight
the dolly is a "tool shop" from home depot, but if you get one that is too low, just upsize 2 of the casters or shim them for clearance. i had tons of clearance.
i have nothing good to say about hell hole issues! good luck with yours.
Joe Ricard
Feb 21 2006, 09:48 AM
I agree with all of the above. Just one thing to add that will make life easier when you get around to doing something with it.
Shove 100.00 dollar bill in each intake port. Put two in the dizzy cap, maybe 3 in the throttle body.
years from now when you don't have enough money to do a rebuild you can use this to get the machine work done.
Bertus
Feb 21 2006, 10:04 AM
QUOTE (Joe Ricard @ Feb 21 2006, 07:48 AM) |
years from now when you don't have enough money to do a rebuild you can use this to get the machine work done. |
What kind of return on interest can I expect?
Along these lines this car came with a Highfire VI, Mallory Promaster coil, and a Mallory Unilite distributer that are not currently installed. I was thinking of installing this summer. Should I expect headaches?
Joe Ricard
Feb 21 2006, 10:15 AM
Nope plug and play. That's what I got on the Red Neck Racer.
