Will 1.8 engine Tin fit 2056 |
Rob K |
Feb 21 2006, 08:38 AM
Newbie Group: Members Posts: 22 Joined: 25-October 05 From: Overland Park, Kansas Member No.: 5,003 |
I am planning to rebuild my 1.8 with one of Jake's 2056 kits in the near future.
Does anyone know if the 1.8 engine tin will fit on a 2056. If not, which pieces need to be replaced/modified? Thanks a bunch (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Rob |
tat2dphreak |
Feb 21 2006, 08:42 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
if the heads are 1.8 or 1.7 heads, then the 1.8 tin will be fine... if the heads are 2.0 or have the spark plug location changed... then the 1.8 tin won't work... you'll need the 2 2.0 top tin pieces
URY914 |
Feb 21 2006, 09:14 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
It's all about the heads. But I was able to relocate my s/p holes when I put 1.7 tin on my new engine that had 2.0 heads. Hole saw and a file was all it took. Than I welded up the old holes with some sheetmetal. |
Rob K |
Feb 21 2006, 10:48 AM
Jakes kit uses modified 1.8 heads, so I think I will be Ok.
Thanks for the reply guys. This forum is a great resource. Rob (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
tat2dphreak |
Feb 21 2006, 10:51 AM
depends... he often relocates the plug location... so I would check with him |
Jake Raby |
Feb 21 2006, 01:24 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The engine kit does have 1.8 spark plug angles. Plug relocation is an option, and if you knew what I knew about the relocation you'd swap to 2 liter tins and get the benefits!
Lo-Fi Version | Time is now: 20th May 2024 - 03:42 PM |
