71 1.7 Not running right |
9magazine |
Feb 21 2006, 09:30 AM
9 Magazine The 914 DIY Publication Group: Members Posts: 96 Joined: 31-March 03 From: Lakeside/Pinetop, Arizona Member No.: 500 |
Okay while our 1975 914 is being sanding down to the metal, and we are hoping for Jake to build us a killer motor for the car... We have to start looking at what to do with our 1971 1.7 car.
It has been sitting for about 2 years (divorce can be a B!tch). And I remembered why I kinda stopped messing with it. She (the car) takes forever to get started, she (again the car) just won't turn over enough... very short movements. Original FI is still on and working as we cleaned all the injectors before. Once running she seems good, will run fine until about 3000 rpm then just seems to say "Whoa, I think I will stay here at 3000" Would love to get this car running if for nothing more than a parts runner until we figure out what to do with it. Wouldn't mind trading it for a 912 with out a motor too! Thanks in advance for your help guys! Brian Minson 9 Magazine http://www.9magazine.com (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
SLITS |
Feb 21 2006, 09:36 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Check your fuel pump....
1.) Forever to start...no fuel pressure in rails when injector is triggered 2.) Running out of steam at 3k.....fuel pressure inadequate Ok, there's my starting point........NEXT |
Joe Ricard |
Feb 21 2006, 09:43 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Yup, that's where I would start.
As for better engine??? why drag Jake in the mess? For an around town or, go from here to eternity on the freeway making 32+ MPG the early 1.7L is a killer engine. |
9magazine |
Feb 21 2006, 10:19 AM
No we are hoping Jake jumps on board for our 1975 project car not for this one.
Okay I will start with the fuel system. Pump is new or was installed when car was put away. Brian Minson 9 Magazine http://www.9magazine.com |
9magazine |
Feb 21 2006, 10:51 AM
Wow, just went to Pelican, Vertex, and Mid-America Motorworks websites to get a new fuel pressure regulator and none of them have them!
Just dropped a line to Zim's in Dallas, anyone have a source for these? Brian Minson 9 Magazine http://www.9magazine.com |
Dave-O |
Feb 21 2006, 10:57 AM
Is winter done yet? Group: Members Posts: 511 Joined: 26-August 03 From: Minneapols, MN Member No.: 1,082 |
The fuel pressure on the stock D-jet fuel system is adjustable and I've never heard of them going bad. Go ahead and do yourself a favor by adding a fuel pressure guage in line just ahead of the pressure regulator. I think my bill from Summit came to less than $10 for the parts and I'm sure you could go to any autoparts store and get the same stuff.
To adjust the fuel pressure regulator loosen the lock nut (13mm I believe) and turn the adjustment screw in for more pressure or out for less (somone please correct me if I got that mixed around). A haynes manual should have the proceedure to do this. If the regulator really is bad I'm sure someone on the board has an extra sitting around that they'll send you. I've got one that I'd send out but it's stored with all my other "junk" at my parent's. Good luck! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
bd1308 |
Feb 21 2006, 10:58 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
if you cant find them anywhere, I have two in a box for you...
b |
Dave-O |
Feb 21 2006, 11:00 AM
Just thought of something else. If you haven't replaced the fuel filter be sure to do that. They're very cheap and can make a world of difference. Just be aware that it may be 30+ years of gunk in the bottom of the fuel tank that is causing the fuel filter to get plugged.
Lo-Fi Version | Time is now: 20th May 2024 - 07:00 AM |
