used springs |
used springs |
sk8kat1 |
Feb 24 2006, 09:31 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
i see quite a few ads for people selling used springs
mostly 140# for right around 40-45 bucks .... but I was offered a set of welmiesters for 70.00 true in very good shape but the only differance I can see is that these come with a top and bottom perch ..? is the perch something special are they nessisary if I am just swaping stock springs to 140# and installing new koni yellows at the same time ? |
dlo914 |
Feb 24 2006, 09:44 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
off my 14' ive got a pair of 140 welts w/ adjustable perched Bilsteins. i'll let them go for $210.
sk8kat1 |
Feb 24 2006, 09:46 PM
thanks for the offer but I already have the konis
Mueller |
Feb 24 2006, 10:28 PM
springs normally don't come with the perch, you re-use the perches already on the shocks....
the welt. springs should be stock diameter, the only time you need a special perch is if you go with the typical 2.5" diameter adjustable spring perches ideally you'll want to sooner or later install threaded spring perches if you get serious with the car...you don't need them but they are nice to have..... for stock diameter springs and adjustable perches see my ugly conversion (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Muellers cheap spring perch mod |
ChicagoChris |
Feb 25 2006, 07:46 AM
It was jack-stand-tastic! Group: Members Posts: 168 Joined: 3-November 05 From: Chicago (burbs), IL Member No.: 5,062 |
If you are looking for stock KONI perches I should have some in the garage you are welcome to. The adjustable perches are nice but free is good too.
Chris |
maf914 |
Feb 25 2006, 08:08 AM
Weltmeister springs fit in the stock perches, the coils are the same diameter. The 140 lb springs are advertised by Weltmeister to lower the rear 1" compared to stock or their 100 lb springs. |
davep |
Feb 25 2006, 12:07 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Springs age. It was not uncommon 15 years ago to find the stock springs curved like a banana while in place. It was so easy to tell that they were toast and had to be replaced. Now that the cars are 30 to 35 years old I can't imagine anyone still running stock springs. I would assume that non-stock springs also age, perhaps not as fast or so obviously. YRMV.
Lo-Fi Version | Time is now: 1st June 2024 - 04:41 PM |
