Sway bar install, where do the u-tabs go? |
robby750 |
Feb 27 2006, 08:23 PM
Senior Member Group: Members Posts: 646 Joined: 6-April 03 From: Lexington, Ky Member No.: 521 Region Association: South East States |
I am installing a stock front sway bar and have done everything but weld on the u-tabs. I have the drop links attached and set the tabs on the a-arms with the suspension unweighted on jack stands where they naturally line up with the ther end of the drop link. Is this the spot to tack them on?
bd1308 |
Feb 27 2006, 08:24 PM
wait, you weld?
sorry for the hijack. b |
robby750 |
Feb 27 2006, 08:28 PM
My brother in law has a welder and is coming over to tack these on. He is an amatuer and I don't know jack about welding so don't get your hopes up.
eeyore |
Feb 27 2006, 08:30 PM
Mueller |
Feb 27 2006, 08:35 PM
make sure he does a good job.....total loss of vehicle control if one of the u-tabs comes off during a high speed corner can happen...not a pretty sight.... |
rjames |
Feb 27 2006, 10:23 PM
I'm made of metal Group: Members Posts: 3,920 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Should one weld these tabs using MIG, or fluxcore? Or is the answer 'it doesn't matter as long as you do it right'? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Mueller |
Feb 27 2006, 10:28 PM
either one.....fluxcore is normally messier and sometimes more difficult to get good penetration.......smack it with a hammer to make sure it doesn't fly off..... |
Mueller |
Feb 27 2006, 10:29 PM
if you want to pay for shipping, I'll send you pair of arms with factory tabs........
Lo-Fi Version | Time is now: 3rd May 2024 - 06:32 AM |
