Simple question on 75' 2.0 |
srb7f |
Feb 27 2006, 08:58 PM
Member Group: Members Posts: 157 Joined: 17-May 04 From: Roswell, GA Member No.: 2,077 Region Association: None |
What is the metal tubing that runs around the fuel injection hoses in the engine compartment and attaches to all four cyllinder heads? Do I need to keep this stuff around? Any input appreciated, as it's definitely not on my 74 1.8. Steve
brp914 |
Feb 27 2006, 09:05 PM
Unregistered |
air injection? wouldn't throw it out, even if not needed for smog testing in your state. might come in handy if you decide to sell sometime in the future.
srb7f |
Feb 27 2006, 09:11 PM
What is air injection, and how does it work to reduce smog?
Allan |
Feb 27 2006, 09:28 PM
Yep, it's the air injection system. It's part of the emissions system. If you don't have required testing in your area it can be removed but you have to plug the ports on the heads.
srb7f |
Feb 27 2006, 09:31 PM
What do people typically use to plug the holes? Do you need to tap them and run bolts in? There's no emission inspections at all in central virginia for any car. Steve
Mueller |
Feb 27 2006, 09:34 PM
unless you are having problems with it, leave it alone....you have a good chance of screwing something up by trying to remove it.....
air gets injected to help further burn any fuel that might be in the exhaust........ |
brp914 |
Feb 27 2006, 09:38 PM
Unregistered |
its already tapped (whats else is holding the injectors in?). iirc, 10mm fine thread, but easy to confirm
srb7f |
Feb 27 2006, 09:49 PM
I had to take the majority of it off to remove the intake manifold and intake pipes. I now have four short little pipes approximately 3 inches or so that stick up from the cyllinder which lie to either side of the injectors which were mounted in the ends of the intake pipes where they dump into the heads. Do these short little pipes need to be removed to take off the engine tin? (BTW, the engine is out of the car on a stand right now).
Mueller |
Feb 27 2006, 10:15 PM
yes, you'll have to remove the pipes.....there have been a few write-ups on the removal and what to install in there place....
air injection "fix"???? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) try searching with key words of air AND injection AND/OR plug for more threads.... |
Allan |
Feb 27 2006, 10:18 PM
I used the valve adjust screw to plug mine with a liberal application of JB weld.
Hope the new owner never needs to remove them. |
srb7f |
Feb 28 2006, 04:39 AM
Thanks for the help guys!
JohnB |
Feb 28 2006, 03:44 PM
Member Group: Members Posts: 107 Joined: 6-June 03 From: Ashburn, VA Member No.: 794 |
I also have a '75 and get to your town often if you want another set of eyes or opinions. My air pump is still installed but the belt is off (it sits near the firewall on the engine on top of the fan shroud).
John |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:59 AM |
