Motor mounts, Alum or rubber or? |
spunone |
Feb 28 2006, 08:34 AM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
What are ya using and why?? (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
IronHillRestorations |
Feb 28 2006, 09:08 AM
Club sports work fine. Just make sure you've got a plate on the top larger than the donut, so if it fails you engine won't be dragging on the ground!
spunone |
Feb 28 2006, 07:05 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) maybe a little more replys this time (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Aaron Cox |
Feb 28 2006, 07:07 PM
i had some nice plastic/delrin types... i balked and gave em to brando..
i love my welt semi solid trans mounts.... hockey puck material... |
spunone |
Feb 28 2006, 07:09 PM
ThX AC thats what I'm talking about (IMG:http://www.914world.com/bbs2/html/emoticons/clap56.gif)
Mueller |
Feb 28 2006, 07:10 PM
Wevo mounts (sold as transmission, but work as engine mounts depending on the year)
spunone |
Feb 28 2006, 07:11 PM
Have a 73 do wevo work on that year??
Aaron Cox |
Feb 28 2006, 07:14 PM
the correct answer is... if you use a tailshifter engine bar... you can use the wevo's..... so nope (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) |
Mueller |
Feb 28 2006, 07:15 PM
yes and no and yes (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) yes = if used on the tranmission only no = you need mounts sold by JWest for stock style yes = if you mount the engine to the bar with solid mounts and run the Wevo mounts on the out board mounts of the bar where it attaches to the chassis (similar to pre-'73 cars) |
spunone |
Feb 28 2006, 07:16 PM
Heard the welts are pretty solid so ya feel every jolt TRUE OR FALSE (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Mueller |
Feb 28 2006, 07:19 PM
true....some people like that....I like a little bit of compliance...ran solids for a while and tossed them.... |
Joe Ricard |
Feb 28 2006, 08:02 PM
Geesh
I used a plastic cutting board for engine mounts 2 1/2 dia. circles four layers thick. Put the motor just high enough to clear the Tangerine pipes to shift rod. PERFECT the trans mounts are a custom design Schedule 80 aluminum pipe welded to 3/8" plate rubber donuts fill the inside of the pipe and the stock through bolt to the trans ear and grade 8 bolts to the body. Hey they were cheap and laying around. Yes after 4 hours driving to an event my cheeks to my feet get pretty numb of course the seat is hard mounted to the floor pan. Be one with the car..... |
Aaron Cox |
Feb 28 2006, 08:04 PM
with the bar moving around like it wasnt designed for (talking 73+ Sideshift engine mount bars) you will hit the shift rod in the bar now that the bar is moving..... |
Mueller |
Feb 28 2006, 08:06 PM
and how much do you think the bar is going to move with better mounts? it would be easy to test..... |
Aaron Cox |
Feb 28 2006, 08:07 PM
burden of proof is on you (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
ChrisFoley |
Mar 1 2006, 06:33 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
On my race car I have aluminum bushings with thru bolts up front the same thickness as the stock rubber mounts. At the rear I have the club sport 911 mounts, which require a little bolt hole ovalizing to mount up. The stack up has to be a little different from original too iirc. I tried the Weltmeister solid rear mounts and didn't like them.
Eric_Shea |
Mar 1 2006, 11:05 AM
Richard from PMO had a rant publicized in one of his ads a while back about solid mounts and engine life.
(that's all I remember... cause I'm old) (IMG:http://www.914world.com/bbs2/html/emoticons/yellowsleep[1].gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:57 PM |
