Rubber boots, for D-Jet injectors |
zymurgist |
Feb 28 2006, 12:40 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Surely I can't be the first person to ask this... I'm looking for a source for the rubber boots for D-Jet injector wiring. Anyone?
Mueller |
Feb 28 2006, 01:21 PM
I got mine from eBay....(IMG:http://www.914world.com/bbs2/uploads/post-2-1098909559.jpg)
Cap'n Krusty |
Feb 28 2006, 06:21 PM
Bowlsby. The Cap'n
rhodyguy |
Feb 28 2006, 07:06 PM
yep, and they come with a harness.
k |
Michael J |
Feb 28 2006, 09:59 PM
Welcome to 2007 Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
So backing up to Ken's question
Can the bubber boots that cover the injector connections be replaced or is the whole harness necessary? |
zymurgist |
Feb 28 2006, 10:03 PM
I could have sworn I saw somebody writing about how to replace the boots, including the use of a special tool to remove the contacts from the plastic plug. I couldn't find that information, though.
bd1308 |
Feb 28 2006, 10:07 PM
if you take a small screwdriver and thin the blade down a tiny bit, you can use it as a pin release tool.
I bought one from NAPA, who carries parts from Beck-Arnley. Its a number from them. like 142-0001 or something. I dunno. I finally broke the tool kinda, but it still works. b |
Krieger |
Feb 28 2006, 10:25 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I rebuilt the entire harness. It wasn't difficult just time consuming. The boots I got from my local BMW dealer. They had a box of assorted size boots, kinda like NAPA has an box of o-rings. The wires came out of the connector plugs with a small eye-glasses type screwdriver. My local import parts shop had all new connector plugs.
Mar 1 2006, 09:37 AM
Mueller's pic shows L-jet connectors, which are different from D-jet ones. Jeff's harness uses a non-stock boot which holds onto the injector better than stock. AFAIK, he only sells the boots with the harness.
A quote from someone, a loooooong time ago....
I know B-A carries the metal pins and the plastic plug bodies, but didn't see the rubber boots in their catalog. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 08:26 PM |
