1.7 with a side shifter |
FlatSix |
Feb 28 2006, 03:31 PM
English Member Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 |
Can I bolt a 1.7 onto a side shifter?
Thanks, Andy |
Mueller |
Feb 28 2006, 03:32 PM
yes.....
FlatSix |
Feb 28 2006, 03:38 PM
Thank goodness for that. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
I've already agreed to purchase the motor, and declined on the tail shifter gearbox! |
jr91472 |
Feb 28 2006, 03:55 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I assume you have the late model motor mounts and support bar?
FlatSix |
Feb 28 2006, 04:02 PM
Umm NO. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) I had converted to a six with a quicksix mounting bar but that engine needs a rebuild. My plan is to install this little engine for the summer. I have 911 engine mounts will they be OK. I need to source an engine mounting bar and the 'long' gearshift rod. |
rhodyguy |
Feb 28 2006, 04:10 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if you are converting an earlier car(stock with tailshifter) you will need the following. the complete shifter assem , the front rod, the adapter bushing in the firewall, the rear shift rod, the engine mount bar, the 2 brackets that bolt to the front of the case, 2 inboard rubber mounts, 2 outboard solid mounts, and the coupler for the rod to trans. consider the other side shift bushing, a ball cup bushing and frt to rear rod coupler bushings. these can be purchased as a complete package.
k |
FlatSix |
Feb 28 2006, 04:13 PM
No, It's a '76.
I will be using the original side shifer gearbox. |
lapuwali |
Feb 28 2006, 04:22 PM
You shouldn't need a different engine mounting bar, then, or any other shifting parts. The 1.7 will all just bolt up. The only thing you may need (but should be able to get off your stock 4, assuming you still have it) are the mounting brackets and rubber mounts that connect the engine to the mounting bar. They're different between tailshift and sideshift, and it's likely the 1.7 you're getting has the tailshift parts on it.
FlatSix |
Feb 28 2006, 04:26 PM
Thanks guys.
I'm collecting the engine this weekend so I'll see then what parts it comes with (and what fits!). Just glad to know that in principle it is a bolt together job, so long as I have the right parts to bolt together. |
Feb 28 2006, 04:27 PM
Custom Member Group: Members Posts: 24,571 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
you need the 4 cylinder engine bar...its a cast iron piece with a hole for the shifter bar.
The rest of your shifter linkage should be the same if you are still running the stock side shifter and you have not bent the rods to accomidate the six. Rich |
Feb 28 2006, 04:29 PM
once you figure it out...take pics of what you have...
I have spares of the rest... Rich |
rhodyguy |
Feb 28 2006, 04:41 PM
there you go. i was unsure exactly how exstensive the swap needs were. if you were going to an early chassis, you would need the whole list. you saved a ton on shipping (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) .
k |
Cap'n Krusty |
Feb 28 2006, 04:45 PM
To clarify the answers, if you're gonna install an engine from a tail shift car into a side shift car, you need the 2 engine mount brackets, the 2 bonded rubber mounts, the engine cross bar, the 2 outer engine mount "channel" pieces, and the associated hardware. You may or may not need a new shift rod from the firewall to the trans shift console. Probably will, IMO. The Cap'n
Lo-Fi Version | Time is now: 3rd May 2024 - 02:09 AM |
