Looking for help on door lock and turn signals, Mo' cars = mo' problems, of course! |
Mike McGrath |
Feb 28 2006, 07:46 PM
Member Group: Members Posts: 98 Joined: 5-December 04 From: Portland, Oregon Member No.: 3,225 |
Very excited to get my first teener this past weekend. Two problems with the car that I couldn't find solutions to in the Haynes book or with a search. Oh ye heavenly gods of knowledge, bless me with an answer...
1. The driver's door doesn't open from the outside. The lever moves / opens, but doesn't open. I haven't yet taken the door apart to look at the insides, but plan to this week. Until then, I crawl through the other side like a noob. 2. The turn signals light when you move the stalk, but they don't click on and off. If I move the stalk left, the light stays on and doesn't blink and the stalk does not return to center after you complete a turn. Also, both light gauges light up when either side is activated. Not a life-threatening problem, as I can do it by hand, but my rthym is affected by whatever is on the stereo. 1970, by the way. Everything else is just as expected and I turned down an S2000 in favor of an Acura contemplating the 914. Crazy, yes, but pointless to have two convertibles in Oregon. Many thanks in advance. I get these projects done and I'm goin' WCC'n this year! Mike (in Portland) |
Joe Ricard |
Feb 28 2006, 08:09 PM
Betcha the plastic do-hickey is broke inside the door handle assy. you can order from Pelican parts. Pretty easy to replace I have done several cars now. Just gotta be able to screw without looking.
Tunr signal relay is dirty. pull the cover off it and spray it with electronic contact cleaner. Or the P.O. screwed you with a relay form FLAPS and it will always light both lights. the auto cancel is part of the steering wheel hub. might be mis aligned. Stock wheel? |
URY914 |
Feb 28 2006, 08:26 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,655 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
For the FULL story on outside door handles go to my blog. I wrote up a full report.
(I know too much about these things) (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
markb |
Feb 28 2006, 08:43 PM
That line is just waaaaaay too easy! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Joe Ricard |
Feb 28 2006, 09:16 PM
Yea loft one up for a home run and it goes by wasted. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
PhoenixINX |
Feb 28 2006, 09:18 PM
Newbie Group: Members Posts: 9 Joined: 19-January 05 From: Nashville, TN Member No.: 3,470 |
Just did the door ... Picked up the replacement part from AA and they designed it to be FAR EASIER to get on, than the older one is to take off.
+1 on the trying to screw it back in blindly. Otherwise, simple hour job! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
VegasRacer |
Feb 28 2006, 10:57 PM
ELVIRA Group: Benefactors Posts: 8,509 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
And you don't even have doors (much less handles) on your car. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
URY914 |
Mar 1 2006, 09:24 AM
Although they are easy to get on the handle, they are at times too "soft" to function properly. I've seen them flex and not be able to provide enough force to release the latch. So they are not perfect. I need to add this comment to my blog with a picture of one that I have that has done this. Paul (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:41 PM |
