| BenNC |
Sep 7 2003, 02:40 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
OK guys I've got at least two things going on. I finally got a good switch (fourth times a charm), but I'm still not starting.
1. I get power going into the relay board, but not coming out. What happens to the juice once it enters the board? I cleaned up the pins and connectors, but I still do not get power out consistantly. 2. When I do get power out the starter turns like a champ, but I am not getting spark all the time. This is a new trick. Is this associated with number 1, or a whole new problem. Thanks |
| BenNC |
Sep 7 2003, 04:04 PM
and in a recent development, my Pertronix unit just burned up. (IMG:style_emoticons/default/headbang.gif)
| TheCabinetmaker |
Sep 7 2003, 04:10 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Ben, what do mean by burned up? be more specific please.
| ChrisReale |
Sep 7 2003, 04:11 PM
Sleazy ![]() ![]() ![]() ![]() Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Probably left the ignition on, like it says not to do.....?
| BenNC |
Sep 7 2003, 04:27 PM
Burned up as in smoke pouring out of the distibutor.
Refresh my memory. Is it bad to leave the switch in the run position or the start position? If its in the run position then I probably killed it when I was troubleshooting my headlights. That would explain why I wasn't getting spark. I just killed it worse now. Good thing I kept the points. |
| TheCabinetmaker |
Sep 7 2003, 04:31 PM
Yes, you burned it up with the ignition on. Put the points back in.
| ChrisReale |
Sep 7 2003, 04:32 PM
pertronix says not to leave the ignition on for more that 10 (?) seconds or else it will burn up the unit. I would use a set of points during the trouble shoot period. If you still have the receipt for the Pertronix, it has a 60 day warranty...?? maybe get another.....?
| BenNC |
Sep 7 2003, 05:00 PM
OK, one problem chalked up to the faulty nut behind the steering wheel.
Now, any thoughts on the relay board. |
| TheCabinetmaker |
Sep 7 2003, 05:16 PM
intermitent spark would suggest a short somewhere. Replace the relays with the ones from the headlight motors. Check voltage at the coil. Make sure all electrical connections are clean and tight.
| Brad Roberts |
Sep 8 2003, 12:34 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Ben..
The relay boards are known to fail. Oh.. word to the wise.. remove the POS coil wire when you are going to have the key in the on position for any longer than 5 minutes (even with points). Bypass the relay board and basically hot wire the coil to the battery.. see if it runs correctly. Then you will know whether or not it is the relay board. B |
| rhodyguy |
Sep 8 2003, 07:11 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
chris, forget an implied warrentee, remember the old "no return on electrical parts". i think lawrence can attest to this as well. i went through 4 or 5 days of misery with my NEW compufire. as geoff wrote,"nice kevin, put in the points and start the car". 10 minutes and it was vrooom.
kevin |
Lo-Fi Version | Time is now: 9th June 2026 - 12:06 AM |
