Weld-thru primer, Necessary? |
rjames |
Mar 5 2006, 03:22 PM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
So from what I can find to read on the subject, weld-thru primer keeps
corrosion from happening, so couldn't I just use metal ready instead? According to the metal ready lable, you can weld to areas that have been 'metal readied'. Getting ready to weld patches in, both using butt-welds, and welding layered pieces together someone please insert the correct term here, I already feel like an idiot). Just wondering if the weld-thru primer was necessary if I coat the back side of the pieces I'm going to weld with metal ready for rust protection (since I won'tbe able to get to them after the welding is done). Thoughts? Lambastings? |
Rand |
Mar 5 2006, 03:56 PM
Metal ready is more of a treatment / rust converter IIRC. Good idea. The primer is a coating on top of that. IMHO, it's a good idea too - some of it will burn off right around the welds, but any little extra layer of protection against rust is good.
Hopefully the areas you are covering / welding up will not be getting exposed to moisture any more. The main thing is the treatment after the welding. That's when a good treatment and paint will seal it up and stave off the rust. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:17 AM |
