So from what I can find to read on the subject, weld-thru primer keeps
corrosion from happening, so couldn't I just use metal ready instead? According
to the metal ready lable, you can weld to areas that have been 'metal readied'.
Getting ready to weld patches in, both using butt-welds, and welding
layered pieces together someone please insert the correct term here,
I already feel like an idiot).
Just wondering if the weld-thru primer was necessary if I
coat the back side of the pieces I'm going to weld with metal ready for rust
protection (since I won'tbe able to get to them after the welding is done).
Thoughts? Lambastings?
