Starting my restoration, 73 914 2.1 L |
Bertus |
Apr 22 2006, 09:44 PM
Member Group: Members Posts: 222 Joined: 2-May 05 From: Lexington, KY Member No.: 4,021 Region Association: South East States |
rotten firewall...
Bertus |
Apr 22 2006, 09:45 PM
replacement piece in...
Bertus |
Apr 22 2006, 09:46 PM
ditto
Bertus |
Apr 22 2006, 09:48 PM
taking paint off of the firewall...
Bertus |
Apr 22 2006, 09:49 PM
POR15 ...
grasshopper |
Apr 22 2006, 09:56 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
wow, that looks awsome! much faster than mine is going. what did you use to strip all of the metal in there???
Bertus |
Apr 22 2006, 10:02 PM
wow, that looks awsome! much faster than mine is going. what did you use to strip all of the metal in there??? Thanks! Kind of a combination of things. In areas where access was not a problem I used a 4" "Stainless steel stringer bead knot wire wheel" (Harbour Freight) it made the fastest work out of paint removal. A good mask is a must when using this because it kicks up the dust! I used assorted wire brushes on the drill, and paint stripper for the hard to get places. It was a lot of work but worth the effort. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:42 PM |
