Installing 19mm mastercyl., Do you use your old elec switch? |
Jaiden |
Mar 6 2006, 09:36 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
So I swapped out my master cyclinder and found that my electrical connections are different that what is on the new master. Do I swap out the old one? Or do you modify the contacts to fit? There is a normal lug on one then a strace center contact in the middle.
What gives? How come none of the instructions note this?? Thanks again. |
ClayPerrine |
Mar 6 2006, 09:46 AM
Life's been good to me so far..... Group: Admin Posts: 15,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There should only be one contact. The second may be the reset button. Oh.. and by the way..... Attached image(s) |
Jaiden |
Mar 6 2006, 09:52 AM
My old master had 2 contacts. So which contact do I use? and what do I do with the other one???
Is one ground? So that would be brown right? |
ClayPerrine |
Mar 6 2006, 09:55 AM
You can swap the switch. Just make sure you retain the sealing ring.
That would be the simplist solution. I would also suggest you bleed the master cylinder before hooking up the lines. That way you don't push as much air into the lines. |
Tobra |
Mar 6 2006, 10:01 AM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Clay is obliquely asking for pictures, looking at diagram, brown and brown and yellow are wires to switch
Jaiden |
Mar 6 2006, 10:04 AM
If I could get out of work I could run home and get some pics loaded but alas I have to find some way of paying for all of these parts!!!
When I get home I'll get some pics loaded. I'm going to check my blog for Master cyl.photos there may be something. |
Jaiden |
Mar 6 2006, 10:06 AM
Check my blog. There is a pic of the old master that shows the contacts.
Is there a way to post an image directly from my blog? |
Lo-Fi Version | Time is now: 14th May 2024 - 06:59 PM |
