Jaiden
Mar 6 2006, 09:36 AM
So I swapped out my master cyclinder and found that my electrical connections are different that what is on the new master. Do I swap out the old one? Or do you modify the contacts to fit? There is a normal lug on one then a strace center contact in the middle.
What gives? How come none of the instructions note this??
Thanks again.
ClayPerrine
Mar 6 2006, 09:46 AM
QUOTE (Jaiden @ Mar 6 2006, 09:36 AM) |
Thanks again. |
There should only be one contact. The second may be the reset button.
Oh.. and by the way.....
Jaiden
Mar 6 2006, 09:52 AM
My old master had 2 contacts. So which contact do I use? and what do I do with the other one???
Is one ground? So that would be brown right?
ClayPerrine
Mar 6 2006, 09:55 AM
You can swap the switch. Just make sure you retain the sealing ring.
That would be the simplist solution.
I would also suggest you bleed the master cylinder before hooking up the lines. That way you don't push as much air into the lines.
Tobra
Mar 6 2006, 10:01 AM
Clay is obliquely asking for pictures, looking at diagram, brown and brown and yellow are wires to switch
Jaiden
Mar 6 2006, 10:04 AM
If I could get out of work I could run home and get some pics loaded but alas I have to find some way of paying for all of these parts!!!
When I get home I'll get some pics loaded. I'm going to check my blog for Master cyl.photos there may be something.
Jaiden
Mar 6 2006, 10:06 AM
Check my blog. There is a pic of the old master that shows the contacts.
Is there a way to post an image directly from my blog?
