> Aluminum face 914 Pressure Plates, Sound interesting to anyone?
Dave from KEP
post Mar 9 2006, 06:20 PM
KEP Clutch Manager
Just thought I'd stop by and let you all know about a new item Kennedy Engineered Products is coming out with. I am the clutch manager here and it was brought to my attention that some of the 914 guys would like a lighter pressure plate since Sachs stopped making theirs. Ours will be out in a month or so but for now I'm only making 50. Ours will make the stock clutch 3 pounds lighter than the original and comes in 2 load ratings for now. We call them Stage 1 and Stage 2 . They have a hard Tungston/Cobalt wear surface. Anyone have any interest or thoughts?
Dave
Aaron Cox
post Mar 9 2006, 06:24 PM
Professional Lawn Dart
that is great that a vendor listens to its purchasers! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
what does the said setup cost?
couple this to a machined/lightened flywheel for seriously light rotating mass (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
post Mar 9 2006, 06:26 PM
Not on that subject, but while you are here, what do you have as far as clutch setups for high torque V8 applications?
How much?
And how is it different/better than the Renegade setup?
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
echocanyons
(IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png) Dave,
Yes that does sound interesting. Do you need a special clutch disk or can yuo run the stock type with this?
Dave from KEP
post Mar 9 2006, 06:28 PM
KEP Clutch Manager
Price I suppose would be helpful. Sorry. It will have a list price of $360.
Dave
Allan
post Mar 9 2006, 06:33 PM
Teenerless Weenie
Will this work on /6 conversions?
J P Stein
Irrelevant old fart
QUOTE (Dave from KEP @ Mar 9 2006, 04:28 PM)
Dave
Humm........I may need one of those.
2 minutes ago, I didn't (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Dave from KEP
post Mar 9 2006, 06:37 PM
KEP Clutch Manager
I must be in the wrong place for replies. Sorry. Just a newbie. I'll answer this way until I learn.
This is for the standard 215mm Pressure plate. It can use any disc intended for use in a 914...Stock, 4 pad metallic, 6pad, etc.
I can't speak for Renegade, but I believe their adaptions use a 228mm pressure plate. We do make those as well, but the aluminum version has not yet been birthed.
Dave
post Mar 9 2006, 06:38 PM
Oops, left out some info.
What are your clutch options for a 914 V8 running a 915 trans?
Dave from KEP
post Mar 9 2006, 06:41 PM
KEP Clutch Manager
I think on the 914/6 conversion, depending on whose kit you use, you need the 228mm version. At least on the KEP conversion it is set up for the 228mm.
Dave
nocones
post Mar 9 2006, 06:42 PM
Sportscar lunatic
I'm interested to know this as well, since I happen to have my V8 separated from my 915 transaxle right now. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
Dave from KEP
post Mar 9 2006, 06:44 PM
KEP Clutch Manager
QUOTE (914-8 @ Mar 9 2006, 04:38 PM)
We have an all aluminum version of our 225mm pressure plate which only weighs 6 lbs. It also uses the Tungston /Cobalt face. They list at $525.
Dave
Randal
post Mar 9 2006, 07:18 PM
Hi Dave,
I'm in.
Cheers,
Randal
fiid
post Mar 9 2006, 07:26 PM
Turbo Megasquirted Subaru Member
Don't need a different pressure plate at this time - but just a shoutout to Kep for making subaru engines bolt to 901 transmissions! Thanks!!
Dave from KEP
post Mar 9 2006, 07:30 PM
KEP Clutch Manager
QUOTE (fiid @ Mar 9 2006, 05:26 PM)
Thank you! We always try our best. We make shortened oil pans too, but I suppose you knew that.
Dave
Jake Raby
post Mar 9 2006, 08:29 PM
Engine Surgeon
Dave, this is what you and I talked about a few weeks back and YES WE DO NEED THEM!
I'll stock a few of them if it helps get them produced.
rick 918-S
post Mar 10 2006, 08:39 AM
Hey nice rack! -Celette
What is the clamping force numbers for the stage II. ? My transaxle is currently out, and my stock parts were slipping.
Can I be more specific?
What are the clampnig force numbers for the stock 1.7 compared to your new Aluminum stage II?
Dave from KEP
post Mar 10 2006, 09:12 AM
KEP Clutch Manager
QUOTE (Jake Raby @ Mar 9 2006, 06:29 PM)
Thanks Jake. We are only a couple weeks away, but I got concerned I don't have enough once the word got out.
Dave
Dave from KEP
post Mar 10 2006, 09:16 AM
KEP Clutch Manager
QUOTE (rick 918-S @ Mar 10 2006, 06:39 AM)
Stock clamping force is about 1200 lbs and is good for about 180 lb/ft of torque with a stock disc.
Stage 1 is 1560, good for 230 lb/ft
Stage 2 is 1840, good for272 lb/ft.
Dave
rick 918-S
post Mar 10 2006, 09:31 AM
QUOTE (Dave from KEP @ Mar 10 2006, 07:16 AM)
Dave
Let us know when their released. I need one.
- Lo-Fi Version Time is now: 14th July 2025 - 08:50 PM
