Suspension rebuild update, Some parts are back on the car! |
Jaiden |
Mar 11 2006, 06:18 PM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
Finally some progress
Check out the pics! Attached thumbnail(s) |
Jaiden |
Mar 11 2006, 06:19 PM
underside
Jaiden |
Mar 11 2006, 06:21 PM
Jaiden |
Mar 11 2006, 06:23 PM
Holes drilled for grease fittings. Bushings have been spiral cut and honed out to a nice slip fit. Just a firm pressure to install or remove the bushings.
Jaiden |
Mar 11 2006, 06:25 PM
Last one Fuel pump relocation Draft 1.
I will make a final adjustment to the lines once I get a new fuel pump. This facet will do for now though. Attached thumbnail(s) |
Sideways |
Mar 11 2006, 07:07 PM
Member Group: Members Posts: 119 Joined: 18-October 05 From: Calgary, AB, Canada Member No.: 4,969 |
What bushings are you using? How did you go about spiral cutting them? |
Jaiden |
Mar 11 2006, 07:14 PM
I got the poly bushings from pelican.
I used a dremel with a 1/4" round cutting bit. I still need to tap for the fittings. |
Aaron Cox |
bogelstiens! (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif)
used a dremel burr tool im guessing on weltmeister poly bushings (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Allan |
Mar 11 2006, 07:18 PM
What is this?
Jeroen |
Mar 11 2006, 07:24 PM
that's the front x-member
where the back end of the front a-arm mounts the hole is for the feed through of the torsion bar |
Aaron Cox |
Mar 11 2006, 07:26 PM
what he said... standard crossmember (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) |
Sideways |
Mar 11 2006, 08:13 PM
Aaron, not a fan of bilsteins? |
Aaron Cox |
Mar 11 2006, 08:15 PM
was a humorous joke.... those are boge housings, with a bilstein dustcap Boge + billstein = bogelstein (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) i have bills on the rear of the beast..... |
Sideways |
Mar 11 2006, 08:16 PM
Justa little slow today.......hold on thats everyday (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
rhodyguy |
Mar 12 2006, 09:27 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,075 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
nice work. your car is going to handle so much better.
k |
Jaiden |
Mar 12 2006, 09:41 AM
Thanks for the moral support! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Yeah I have bills installed up front now. The interesting thing was when I pulled the old struts out they were red Koni's!!!!!! I already had the bills and the Koni's are definitly worn. Aren't the koni's rebuildable? I can't wait to get it back on the road. I'm still waiting for an A-arm and 1 ball joint and some torsion felts so I can put it all back together. Then I just have to wait for my calipers and rotors to get it on the road. I'll post up more picks when that happens! Spring is getting near I wanna get this car on the road! |
Lo-Fi Version | Time is now: 10th May 2024 - 06:50 AM |
