Finally some progress
Check out the pics!
QUOTE (Jaiden @ Mar 11 2006, 05:23 PM) |
Holes drilled for grease fittings. Bushings have been spiral cut and honed out to a nice slip fit. Just a firm pressure to install or remove the bushings. |
QUOTE (Jeroen @ Mar 11 2006, 06:24 PM) |
that's the front x-member where the back end of the front a-arm mounts the hole is for the feed through of the torsion bar |
QUOTE (Aaron Cox @ Mar 11 2006, 06:14 PM) |
bogelstiens! used a dremel burr tool im guessing on weltmeister poly bushings |
QUOTE (Sideways @ Mar 11 2006, 07:13 PM) | ||
Aaron, not a fan of bilsteins? |
QUOTE (Aaron Cox @ Mar 11 2006, 07:15 PM) | ||||
was a humorous joke.... those are boge housings, with a bilstein dustcap Boge + billstein = bogelstein i have bills on the rear of the beast..... |
