| watsonrx13 |
Mar 11 2006, 08:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, I have been having a problem with the engine overheating and decided to change the idle jets from 50s to 55s. After I changed the jets, the fuel pump quit working. BTW, I have dual weber IDF 40s, with the fuel pump mounted underneath the fuel tank. I have a fuel filter between the fuel tank and pump, with another filter between the fuel pump and the carbs in the engine compartment.
It appears that there is no power to the fuel pump, which I spliced into the engine compartment at the original fuel pump line, then ran the new wires through the center tunnel to the front. I need to verify that there is power to the pump, how do I check the electrical connections in the relay box? Any other recommendations are requested. I'm also planning to check and/or replace the two fuel filters and maybe the fuel sock in the tank. -- Rob |
watsonrx13 Fuel pump quit working Mar 11 2006, 08:18 PM
SirAndy ![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 03:28 AM |
